| comentario del autor | Dom Oct 28, 2007 2:27 pm | |
AYUDA POR FAVOR CON UN MODELO DE DSC ALARMA Q JAMAS VI EN MI VIDA les cuento tengo un problema con ana alarma dsc 1575-1580 de 6 zonas la cual ya la programe toda pero el unico problema q tengo es que la zona 1 y 2, las tengo con tiempo de entrada y salida el cual ya programe de la siguiente forma , pero "me tengo que quedar quieto" para q se me prenda la luz de listo..??? LES AGRADESCO DE TODO CORAZON FIDOLOCKO.. ACA LES DEJO TODA LA PROGRAMACION COMPLETA DE DSC ESTA TODO CONFUGURADO PARA Q LLAME POR TELEFONO CUANDO SUENA LA ALARMA, SOLO TIENE Q PONER LOS NUMEROS A LOS Q QUIERAN Q LLAME EN EL PASO 31, 32 Y 33. RECUERDEN Q SOLO DA SEÑAL DE FAX LA IDEA ES PONER EL CELULAR ASI SALE EL NUMERO DE TEL Y CUANDO ATENDES SUENA FAX Y ES POR Q ESTA SONANDO LA ALRMA.. LINK DEL MANUAL DE PROGRAMACION http://www.avss.net/dsc%20pc1575%20install.pdf [01] Zone 1-6 Definitions (Section 5.2 “Zone Definitions”) Default Default 01 I___01____I Zone 1 03 I___03___I Zone 4 06 I___02____I Zone 2 03 I___03___I Zone 5 03 I___03____I Zone 3 03 I___03___I Zone 6 [02] System Times Default [000-255] 030 I___030___I Entry Delay 1 045 I___030___I Entry Delay 2 120 I___030___I Exit Delay 004 I___004___I Bell Cutoff [03] Installer’s Code (Section 4 “How to Program”) Default 1575 I___1____I___5___I___7____I___5____I [04] Master Code (Section 5.1 “Programming Security Codes”) Default 1234 I___1____I____2___I___3____I___4____I [05] Second Master Code (Section 5.1 “Programming Security Codes”) Default AAAA I___1____I____1___I___1____I____1___I Default Default 02 I____0___I____2___I PGM1 08 I____0___I___8____I PGM2 [07] Keypad Lockout Options (Section 5.19 “Keypad Lockout”) Default 00 I___0____I___5___I Number of Invalid Codes Before Lockout 00 I___0___I____2___I Lockout Duration (in minutes) [08] First System Option Code Default Option ON OFF Section OFF I__APAGADO_______I 1 Normally Closed Loops End-of-Line Resistors 2.8 OFF I___APAGADO______I 2 Double End-of-Line Resistors Single End-of-Line Resistors 2.8 ON I___APAGADO______I 3 [F] Key Enabled [F] Key Disabled 5.13 OFF I___ENCENDIDO_____I 4 [P] Key Audible Bell and Buzzer [P] Key Silent Bell and Buzzer 5.13 ON I___ENCENDIDO_____I 5 TLM Enabled TLM Disabled 5.10 OFF I___ENCENDIDO_____I 6 TLM Audible When Armed TLM Trouble Only When Armed 5.10 [ 09] Second System Option Code Default Option ON OFF Section OFF I___AP_____I 1 Master Code Not Changeable Master Code Changeable 5.1 OFF I___AP_____I 2 Code Required For Bypassing No Code Required 5.1 OFF I___EN_____I 3 6th Code is Duress Code 6th Code is Normal Code 5.1 OFF I___EN_____I 4 Quick Exit Enabled Quick Exit Disabled 3.4 OFF I___EN_____I 5 Bypass Status Displayed While Armed Bypass Status Not Displayed While Armed 3.4 ON I____EN____I 6 AC Trouble Displayed AC Trouble Not Displayed 3.4 [10] Third System Option Code Default Option ON OFF Section OFF I__APA______I 1 Arm / Disarm Bell Squawk Enabled Arm m / Disarm Bell Squawk Disabled 5.14 OFF I___APA_____I 2 Bell Squawk During Auto Arm No Bell Squawk During Auto Arm 5.15 OFF I___APA_____I 3 Bell Squawk On Exit Delay No Bell Squawk On Exit Delay 5.15 OFF I___APA_____I 4 Bell Squawk On Entry Delay No Bell Squawk On Entry Delay 5.15 ON I____ENC____I 5 Audible Exit With Urgency Silent Exit Delay 5.15 ON I____ENC____I 6 Quick Arm Enabled Quick Arm Disabled 3.4 [11] Fourth System Option Code Default Option ON OFF Section OFF I___APA_____I 1 For Future Use ON I____ENC____I 2 Event Buffer Follow Swinger Shutdown Event Buffer Never Shuts Down 5.18 ON I____ENC____I 3 Trouble Light Flashes If AC Fails Trouble Light Does Not Flash If AC Fails 3.4 OFF I___APA_____I 4 Exit Delay Termination Enabled Exit Delay Termination Disabled 5.15 OFF I___APA_____I 5 Keypad Blanking Enabled Keypad Blanking Disabled 5.20 OFF I___ENC_____I 6 Keypad Tampers Enabled Keypad Tampers Disabled 5.22 Zone 1-6 Attributes (Section 5.3 “Zone Attributes”) Opt. 1 Opt. 2 Opt. 3 Opt. 4 Opt. 5 Opt. 6 On Audible Steady Chime Force Bypass Downlook Off Silent Pulsed No No No No [21] Zone 1 I________| I________| I________| I________| I________| I________I [22] Zone 2 I________| I________| I________| I________| I________I I________I [23] Zone 3 I________| I________| I________| I________| I________I I________I [24] Zone 4 I________| I________| I________| I________| I________I I________I [25] Zone 5 I________| I________| I________| I________| I________I I________I [26] Zone 6 I________| I________| I________| I________| I________I I________I Zone Attribute Defaults Note: For sections [31] to [46], the contents of every section by default is [F]. [31] First Telephone Number (32 Digits) (Section 5.6 “Communicator – Phone Numbers”) I__X__I__X__I__X__I__X__I__X__I__X__I__X__I__X__I__X__I__X__I__X__I__X__I___X_I____I___ [32] Second Telephone Number (32 Digits) (Section 5.6 “Communicator – Phone Numbers”) I___X__I__X___I___X__I__X___I___X__I___X__I___X__I___X__I____X_I___X__I_____I_____I_____I [33] Third Telephone Number (32 Digits) (Section 5.6 “Communicator – Phone Numbers”) I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I [34] First Account Code (4 digits) (Section 5.5 “Communicator – Account Numbers”) I___1___I___0____I__1____I___0____I [35] Second Account Code (4 digits) (Section 5.5 “Communicator – Account Numbers”) I____0___I___0____I___0____I___0____I [36] Alarm Reporting Codes, Zones 1-6 (Section 5.7 “Communicator – Reporting Codes”) I____0___I___1____I Zone 1 I___0____I___4____I Zone 4 I___1____I___0____I Police Code Alarm I____0___I____2___I Zone 2 I___0____I___5____I Zone 5 I____0___I____3___I Zone 3 I___0____I___6____I Zone 6 [37] Alarm Restoral Reporting Codes, Zones 1-6 (Section 5.7 “Communicator – Reporting Codes”) I_______I_______I Zone 1 I_______I_______I Zone 4 I_______I_______I Opening After Alarm I_______I_______I Zone 2 I_______I_______I Zone 5 I_______I_______I Zone 3 I_______I_______I Zone 6 [38] Tamper Reporting Codes, Zones 1-6 (Section 5.7 “Communicator – Reporting Codes”) I_______I_______I Zone 1 I_______I_______I Zone 4 I_______I_______I General System I_______I_______I Zone 2 I_______I_______I Zone 5 Tamper Alarm I_______I_______I Zone 3 I_______I_______I Zone 6 [39] Tamper Restoral Reporting Codes, Zones 1-6 (Section 5.7 “Communicator – Reporting Codes”) I_______I_______I Zone 1 I_______I_______I Zone 4 I_______I_______I General System I_______I_______I Zone 2 I_______I_______I Zone 5 Tamper Restoral I_______I_______I Zone 3 I_______I_______I Zone 6 [40] Priority Alarm and Restoral Reporting Codes (Section 5.7 “Communicator – Reporting Codes”) I_______I_______I Keypad [F]ire Alarm I_______I_______I PGM2 Alarm I_______I_______I Keypad [A]uxiliary Restoral I_______I_______I Keypad [A]uxiliary Alarm I_______I_______I Duress Code Alarm I_______I_______I Keypad [P]anic Restoral I_______I_______I Keypad [P]anic Alarm I_______I_______I Keypad [F]ire Restoral I_______I_______I PGM2 Restoral [41] Closing (Arming) Reporting Codes, Access Codes 1-6 (Section 5.7 “Communicator – Reporting Codes”) I_______I_______I Closing by Access Code 1 / 2nd Master / Key switch / Auto Arm I_______I_______I Closing by Access Code 2 I_______I_______I Closing by Access Code 5 I_______I_______I Closing by Access Code 3 I_______I_______I Closing by Access Code 6 I_______I_______I Closing by Access Code 4 I_______I_______I Partial Closing Code Communicator Programming [42] Opening (Disarming) ming) Reporting Codes, Access Codes 1-6 (Section 5.7 “Communicator – Reporting Codes”) I_______I_______I Opening by Access Code 1 / 2nd Master / Key switch I_______I_______I Opening by Access Code 2 I_______I_______I Opening by Access Code 5 I_______I_______I Opening by Access Code 3 I_______I_______I Opening by Access Code 6 I_______I_______I Opening by Access Code 4 [43] Miscellaneous Closing (Arming) Reporting Codes (Section 5.7 “Communicator – Reporting Codes”) I_______I_______I Battery Trouble Alarm I_______I_______I AUX Fuse Failure Alarm I_______I_______I AC Failure Trouble Alarm I_______I_______I TLM Trouble Code (via LINKS) I_______I_______I Bell Circuit Trouble Alarm I_______I_______I General System Supervisory I_______I_______I Fire Trouble Alarm [44] Maintenance Restoral Reporting Codes (Section 5.7 “Communicator – Reporting Codes”) I_______I_______I Battery Trouble Restoral I_______I_______I AUX Fuse Trouble Restoral I_______I_______I AC Failure Trouble Restoral I_______I_______I TLM Restoral I_______I_______I Bell Circuit Trouble Restoral I_______I_______I General System Supervisory Restoral I_______I_______I Fire Trouble Restoral [45] Miscellaneous Maintenance Reporting Codes (Section 5.7 “Communicator – Reporting Codes”) I_______I_______I Phone Number 1 Failure to Communicate I_______I_______I General Zone Fault Alarm I_______I_______I Phone Number 2 Failure to Communicate I_______I_______I General Zone Fault Restoral I_______I_______I Event Buffer is 75% Full Since Last Upload I_______I_______I Delinquency Reporting Code [46] Test Transmission Reporting Codes (Section 5.7 “Communicator – Reporting Codes”) I_______I_______I Periodic Test Transmission I_______I_______I System Test I_______I_______I LINKS 1000 Test Transmission Code [50] Communicator Format Options (Section 5.8 “Communicator – Reporting Formats”) Default 02 I___0____I___2____I 1st Phone Number 02 I___0____I____2___I 2nd Phone Number 01 20 BPS, 1400 HZ handshake 04 SIA FSK 02 20 BPS, 2300 HZ handshake 05 Pager Format 03 DTMF CONTACT I.D. [51] Zone Alarms & Restorals Communicator Call Directions (Section 5.4 “Communicator – Dialing”) Default Option ON OFF ON I___APA____I 1 1st Telephone Number Disabled OFF I__APA_____I 2 2nd Telephone Number Disabled OFF I__APA_____I 3 1st Telephone Number (via LINKS) Disabled OFF I__APA_____I 4 2nd Telephone Number (via LINKS) Disabled [52] Zone Tamper Alarms & Tamper Restorals Communicator Call Directions (Section 5.4 “Communicator – Dialing”) Default Option ON OFF ON I___APAGADO_____I 1 1st Telephone Number Disabled OFF I__APA______I 2 2nd Telephone Number Disabled OFF I__APA______I 3 1st Telephone Number (via LINKS) Disabled OFF I__APA______I 4 2nd Telephone Number (via LINKS) Disabled [53] Openings & Closings Communicator Call Directions (Section 5.4 “Communicator – Dialing”) Default Option ON OFF ON I____A____I 1 1st Telephone Number Disabled OFF I___A_____I 2 2nd Telephone Number Disabled OFF I___A_____I 3 1st Telephone Number (via LINKS) Disabled OFF I___A_____I 4 2nd Telephone Number (via LINKS) Disabled [54] System Maintenance Alarms & Restorals Communicator Call Directions (Section 5.4 “Communicator – Dialing”) Default Option ON OFF ON I__A______I 1 1st Telephone Number Disabled OFF I__A______I 2 2nd Telephone Number Disabled OFF I__A______I 3 1st Telephone Number (via LINKS) Disabled OFF I__A______I 4 2nd Telephone Number (via LINKS) Disabled [55] System Test Transmissions Communicator Call Directions (Section 5.4 “Communicator – Dialing”) Default Option ON OFF ON I___A_____I 1 1st Telephone Number (Periodic Test TX and System Test Only) Disabled OFF I___A_____I 2 2nd Telephone Number (Periodic Test TX and System Test Only) Disabled OFF I___A_____I 3 1st Telephone Number (via LINKS) (LINKS 1000 Test TX Code Only) Disabled OFF I___A_____I 4 2nd Telephone Number (via LINKS) (LINKS 1000 Test TX Code Only) Disabled [60] First Communicator Option Code Default Option ON OFF Section ON I___ENC____I 1 Communications Enabled Communications Disabled 5.4 ON I___ENC____I 2 DTMF Dialing Pulse Dialing 5.4 ON I___APA____I 3 Switch to Pulse Dialing on 5th Attempt DTMF Dial For All 8 Attempts 5.4 OFF I__ENCE_____I 4 3rd Phone Number Enabled 3rd Phone Number Disabled 5.6 OFF I__ENCE_____I 5 Alternate Dial (1st and 3rd) Call 1st Number, Backup to 3rd (If programmed) 5.6 OFF I__APA_____I 6 Restorals on Bell Time-out Restorals Follow Zones 5.7.2 [61] Second Communicator Option Code Default Option ON OFF Section OFF I___ENC____I 1 Closing Confirmation Enabled Closing Confirmation Disabled 5.7.3 OFF I___ENC____I 2 Opening After Alarm Keypad Open After Alarm Bell Ringback Disabled 5.7.4 Ringback Enabled OFF I___APA____I 3 Opening After Alarm Bell Opening After Alarm Bell Ringback Disabled 5.7.4 Ringback Enabled OFF I___A____I 4 Busy Tone Detection Enabled Busy Tone Detection Disabled 5.4 OFF I___A____I 5 Call LINKS As Well As Land Line LINKS is Backup of Land Line(s) OFF I___A____I 6 SIA Sends Programmed Rep. Codes SIA Sends Automatic Rep. Codes 5.8.3 [62] Communication Variables Default Section 003 I____0___I___2____I___0____I Swinger Shutdown (Alarms and Rest) (001-014 Transmissions, 000=disabled) 5.16 000 I____0___I___0____I___1____I Transmission Delay (001-255 seconds) 5.17 030 I____0___I___0____I___1____I AC Failure Communication Delay (001-255 minutes) 5.7.7 003 I____0___I___0____I___1____I TLM Trouble Delay (No. of valid checks required - 000-255 x 10s) 5.10 030 I____0___I___0____I___1____I Test Transmission Cycle (001-255 days) 5.12 030 I____0___I___0____I___1____I Delinquency Transmission Delay (000-255 days) 5.7.9 [63] Test Transmission Time of Day (Section 5.12 “Test Transmission”) Default 9999 I_______I_______I_______I_______I (Valid entries are 0000-2359, 9999 to disable) [67] LINKS 1000 Preamble (First Telephone Number) (Section 5.23 “LINKS 1000 Cellular Communicator”) Default FFFF I_______I_______I_______I_______I (Program all unused digits with Hex F) [68] LINKS 1000 Preamble (Second Telephone Number) (Section 5.23 “LINKS 1000 Cellular Communicator”) Default FFFF I_______I_______I_______I_______I (Program all unused digits with Hex F) [69] LINKS 1000 Preamble (Third Telephone Number) (Section 5.23 “LINKS 1000 Cellular Communicator”) Default FFFF I_______I_______I_______I_______I (Program all unused digits with Hex F) [70] Number of Rings to Answer On (Section 5.9 “Downloading”) Default 1 2 I_______I_______I (Valid entries are 00-99) [71] First Downloading Option Code (Section 5.9 “Downloading”) Default Option ON OFF OFF I___EN____I 1 Downloading Answer Enabled Downloading Answer Disabled ON I____EN___I 2 User Can Enable DLS Window for One Hour User Cannot Enable DLS Window OFF I___EN____I 3 Call-Back Enabled Call-Back Disabled OFF I___EN____I 4 User Initiated Call-up Enabled User Initiated Call-up Disabled OFF I___EN____I 5 Periodic Download at Test TX Time No Periodic Download OFF I___EN____I 6 Answering Machine Override Enabled Answering Machine Override Disabled [72] Downloading Computer’s Telephone Number (32 Digits) (Section 5.9 “Downloading”) I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I [73] Downloading Access Code (Section 5.9 “Downloading”) Default 1575 I_______I_______I_______I_______I Enter 4 Hexadecimal Digits [74] Panel Identification Code (Section 5.9 “Downloading”) Default 1575 I_______I_______I_______I_______I Enter 4 Hexadecimal Digits [75] Answering Machine Double-call Timer (Section 5.9 “Downloading”) Default 060 I_______I_______I_______I (Valid entries are 001-255 seconds) [77] [Installer Code] [77] Initiate Local Downloading (PC-LINK) (Section 5.9 “Downloading”) [79] LINKS 1000 Preamble (Downloading Telephone Number) (Section 5.9 “Downloading”) Default FFFF I_______I_______I_______I_______I (Program all unused digits with Hex F) Downloading Programming [87]PC5400 Programming (Printer Module) (Section 5.24 “On-Site Printer”) [01] Printer Configuration Default Option ON OFF OFF I________I 1 Printer Enabled Printer Disabled ON I________I 2 Handshake from Printer No Handshake OFF I________I 3 80 Column Printer 40 Column Printer OFF I________I 4 300 Baud Enabled Disabled OFF I________I 5 1200 Baud Enabled Disabled ON I________I 6 2400 Baud Enabled Disabled [05] Printer Language Selection Default 01 I________I________I (01=English 02=French 03=Spanish) [88] DLM-1/DLM-4 Support Timers (Section 5.25 “Downlook Video Transmission Module”) Default 01 I________I________I Number of Pictures (Valid Entries are 01-0 00 I________I________I Delay Before Capture at 100ms increments (Valid Entries are 00-99) [90] [Installer’s Code] [90] Installer Lockout Enable (Section 5.27 “Installer’s Lockout”) Enter [90] [Installer’s Code] [90] [91] [Installer’s Code] [91] Installer Lockout Disable (Section 5.27 “Installer’s Lockout”) Enter [91] [Installer’s Code] [91] [92] [Installer’s Code] [92] Module Supervision Reset (Section 2.6 “Supervision”) Enter [91] [Installer’s Code] [91] [95] [Installer’s Code] [95] Restore ESCORT to Factory Default Programming (Section 5.26 “Resetting Factory Defaults”) Enter [95] [Installer’s Code] [95] [97] [Installer’s Code] [97] Restore PC5400 to Factory Default Programming (Section 5.26 “Resetting Factory Defaults”) Enter [96] [Installer’s Code] [96] [99] [Installer’s Code] [99] Restore PC1575 to Factory Default Programming (Section 5.26 “Resetting Factory Defaults”) Enter [99] [Installer’s Code] [99] |
| comentario | Mie Oct 31, 2007 12:21 pm | |
| asistió a la solución | Vie Nov 02, 2007 3:50 pm | |
Espero te sirva. Atte egsystem |
