programacion dsc 1575/1580
comentario del autor Dom Oct 28, 2007 2:20 pm
***********HOLA COMO ESTAN..*************
AYUDA POR FAVOR CON UN MODELO DE DSC ALARMA Q JAMAS VI EN MI VIDA
les cuento tengo un problema con ana alarma dsc 1575-1580 de 6 zonas la cual ya la programe toda pero el unico problema q tengo es que la zona 1 y 2, las tengo con tiempo de entrada y salida el cual ya programe de la siguiente forma , pero "me tengo que quedar quieto" para q se me prenda la luz de listo..??? LES AGRADESCO DE TODO CORAZON FIDOLOCKO..
ACA LES DEJO TODA LA PROGRAMACION COMPLETA DE DSC
ESTA TODO CONFUGURADO PARA Q LLAME POR TELEFONO CUANDO SUENA LA ALARMA, SOLO TIENE Q PONER LOS NUMEROS A LOS Q QUIERAN Q LLAME EN EL PASO 31, 32 Y 33. RECUERDEN Q SOLO DA SEÑAL DE FAX LA IDEA ES PONER EL CELULAR ASI SALE EL NUMERO DE TEL Y CUANDO ATENDES SUENA FAX Y ES POR Q ESTA SONANDO LA ALRMA..
LINK DEL MANUAL DE PROGRAMACION
http://www.avss.net/dsc%20pc1575%20install.pdf
[01] Zone 1-6 Definitions (Section 5.2 “Zone Definitions”)
Default Default
01 I___01____I Zone 1 03 I___03___I Zone 4
06 I___02____I Zone 2 03 I___03___I Zone 5
03 I___03____I Zone 3 03 I___03___I Zone 6
[02] System Times
Default [000-255]
030 I___030___I Entry Delay 1
045 I___030___I Entry Delay 2
120 I___030___I Exit Delay
004 I___004___I Bell Cutoff
[03] Installer’s Code (Section 4 “How to Program”)
Default
1575 I___1____I___5___I___7____I___5____I
[04] Master Code (Section 5.1 “Programming Security Codes”)
Default
1234 I___1____I____2___I___3____I___4____I
[05] Second Master Code (Section 5.1 “Programming Security Codes”)
Default
AAAA I___1____I____1___I___1____I____1___I
Default Default
02 I____0___I____2___I PGM1 08 I____0___I___8____I PGM2
[07] Keypad Lockout Options (Section 5.19 “Keypad Lockout”)
Default
00 I___0____I___5___I Number of Invalid Codes Before Lockout
00 I___0___I____2___I Lockout Duration (in minutes)
[08] First System Option Code
Default Option ON OFF Section
OFF I__APAGADO_______I 1 Normally Closed Loops End-of-Line Resistors 2.8
OFF I___APAGADO______I 2 Double End-of-Line Resistors Single End-of-Line Resistors 2.8
ON I___APAGADO______I 3 [F] Key Enabled [F] Key Disabled 5.13
OFF I___ENCENDIDO_____I 4 [P] Key Audible Bell and Buzzer [P] Key Silent Bell and Buzzer 5.13
ON I___ENCENDIDO_____I 5 TLM Enabled TLM Disabled 5.10
OFF I___ENCENDIDO_____I 6 TLM Audible When Armed TLM Trouble Only When Armed 5.10
09] Second System Option Code
OFF I___AP_____I 1 Master Code Not Changeable Master Code Changeable 5.1
OFF I___AP_____I 2 Code Required For Bypassing No Code Required 5.1
OFF I___EN_____I 3 6th Code is Duress Code 6th Code is Normal Code 5.1
OFF I___EN_____I 4 Quick Exit Enabled Quick Exit Disabled 3.4
OFF I___EN_____I 5 Bypass Status Displayed While Armed Bypass Status Not Displayed While Armed 3.4
ON I____EN____I 6 AC Trouble Displayed AC Trouble Not Displayed 3.4
[10] Third System Option Code
OFF I__APA______I 1 Arm / Disarm Bell Squawk Enabled Arm m / Disarm Bell Squawk Disabled 5.14
OFF I___APA_____I 2 Bell Squawk During Auto Arm No Bell Squawk During Auto Arm 5.15
OFF I___APA_____I 3 Bell Squawk On Exit Delay No Bell Squawk On Exit Delay 5.15
OFF I___APA_____I 4 Bell Squawk On Entry Delay No Bell Squawk On Entry Delay 5.15
ON I____ENC____I 5 Audible Exit With Urgency Silent Exit Delay 5.15
ON I____ENC____I 6 Quick Arm Enabled Quick Arm Disabled 3.4
[11] Fourth System Option Code
OFF I___APA_____I 1 For Future Use
ON I____ENC____I 2 Event Buffer Follow Swinger Shutdown Event Buffer Never Shuts Down 5.18
ON I____ENC____I 3 Trouble Light Flashes If AC Fails Trouble Light Does Not Flash If AC Fails 3.4
OFF I___APA_____I 4 Exit Delay Termination Enabled Exit Delay Termination Disabled 5.15
OFF I___APA_____I 5 Keypad Blanking Enabled Keypad Blanking Disabled 5.20
OFF I___ENC_____I 6 Keypad Tampers Enabled Keypad Tampers Disabled 5.22
Zone 1-6 Attributes (Section 5.3 “Zone Attributes”)
Opt. 1 Opt. 2 Opt. 3 Opt. 4 Opt. 5 Opt. 6
On Audible Steady Chime Force Bypass Downlook
Off Silent Pulsed No No No No
[21] Zone 1 I________| I________| I________| I________| I________| I________I
[22] Zone 2 I________| I________| I________| I________| I________I I________I
[23] Zone 3 I________| I________| I________| I________| I________I I________I
[24] Zone 4 I________| I________| I________| I________| I________I I________I
[25] Zone 5 I________| I________| I________| I________| I________I I________I
[26] Zone 6 I________| I________| I________| I________| I________I I________I
Zone Attribute Defaults
Note: For sections [31] to [46], the contents of every section by default is [F].
[31] First Telephone Number (32 Digits) (Section 5.6 “Communicator – Phone Numbers”)
I__X__I__X__I__X__I__X__I__X__I__X__I__X__I__X__I__X__I__X__I__X__I__X__I___X_I____I___
[32] Second Telephone Number (32 Digits) (Section 5.6 “Communicator – Phone Numbers”)
I___X__I__X___I___X__I__X___I___X__I___X__I___X__I___X__I____X_I___X__I_____I_____I_____I
[33] Third Telephone Number (32 Digits) (Section 5.6 “Communicator – Phone Numbers”)
I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I
[34] First Account Code (4 digits) (Section 5.5 “Communicator – Account Numbers”)
I___1___I___0____I__1____I___0____I
[35] Second Account Code (4 digits) (Section 5.5 “Communicator – Account Numbers”)
I____0___I___0____I___0____I___0____I
[36] Alarm Reporting Codes, Zones 1-6 (Section 5.7 “Communicator – Reporting Codes”)
I____0___I___1____I Zone 1 I___0____I___4____I Zone 4 I___1____I___0____I Police Code Alarm
I____0___I____2___I Zone 2 I___0____I___5____I Zone 5
I____0___I____3___I Zone 3 I___0____I___6____I Zone 6
[37] Alarm Restoral Reporting Codes, Zones 1-6 (Section 5.7 “Communicator – Reporting Codes”)
I_______I_______I Zone 1 I_______I_______I Zone 4 I_______I_______I Opening After Alarm
I_______I_______I Zone 2 I_______I_______I Zone 5
I_______I_______I Zone 3 I_______I_______I Zone 6
[38] Tamper Reporting Codes, Zones 1-6 (Section 5.7 “Communicator – Reporting Codes”)
I_______I_______I Zone 1 I_______I_______I Zone 4 I_______I_______I General System
I_______I_______I Zone 2 I_______I_______I Zone 5 Tamper Alarm
[39] Tamper Restoral Reporting Codes, Zones 1-6 (Section 5.7 “Communicator – Reporting Codes”)
I_______I_______I Zone 2 I_______I_______I Zone 5 Tamper Restoral
[40] Priority Alarm and Restoral Reporting Codes (Section 5.7 “Communicator – Reporting Codes”)
I_______I_______I Keypad [F]ire Alarm I_______I_______I PGM2 Alarm I_______I_______I Keypad [A]uxiliary Restoral
I_______I_______I Keypad [A]uxiliary Alarm I_______I_______I Duress Code Alarm I_______I_______I Keypad [P]anic Restoral
I_______I_______I Keypad [P]anic Alarm I_______I_______I Keypad [F]ire Restoral I_______I_______I PGM2 Restoral
[41] Closing (Arming) Reporting Codes, Access Codes 1-6 (Section 5.7 “Communicator – Reporting
Codes”)
I_______I_______I Closing by Access Code 1 / 2nd Master / Key switch / Auto Arm
I_______I_______I Closing by Access Code 2 I_______I_______I Closing by Access Code 5
I_______I_______I Closing by Access Code 3 I_______I_______I Closing by Access Code 6
I_______I_______I Closing by Access Code 4 I_______I_______I Partial Closing Code
Communicator Programming
[42] Opening (Disarming) ming) Reporting Codes, Access Codes 1-6 (Section 5.7 “Communicator – Reporting
Codes”)
I_______I_______I Opening by Access Code 1 / 2nd Master / Key switch
I_______I_______I Opening by Access Code 2 I_______I_______I Opening by Access Code 5
I_______I_______I Opening by Access Code 3 I_______I_______I Opening by Access Code 6
I_______I_______I Opening by Access Code 4
[43] Miscellaneous Closing (Arming) Reporting Codes (Section 5.7 “Communicator – Reporting Codes”)
I_______I_______I Battery Trouble Alarm I_______I_______I AUX Fuse Failure Alarm
I_______I_______I AC Failure Trouble Alarm I_______I_______I TLM Trouble Code (via LINKS)
I_______I_______I Bell Circuit Trouble Alarm I_______I_______I General System Supervisory
I_______I_______I Fire Trouble Alarm
[44] Maintenance Restoral Reporting Codes (Section 5.7 “Communicator – Reporting Codes”)
I_______I_______I Battery Trouble Restoral I_______I_______I AUX Fuse Trouble Restoral
I_______I_______I AC Failure Trouble Restoral I_______I_______I TLM Restoral
I_______I_______I Bell Circuit Trouble Restoral I_______I_______I General System Supervisory Restoral
I_______I_______I Fire Trouble Restoral
[45] Miscellaneous Maintenance Reporting Codes (Section 5.7 “Communicator – Reporting Codes”)
I_______I_______I Phone Number 1 Failure to Communicate I_______I_______I General Zone Fault Alarm
I_______I_______I Phone Number 2 Failure to Communicate I_______I_______I General Zone Fault Restoral
I_______I_______I Event Buffer is 75% Full Since Last Upload I_______I_______I Delinquency Reporting Code
[46] Test Transmission Reporting Codes (Section 5.7 “Communicator – Reporting Codes”)
I_______I_______I Periodic Test Transmission
I_______I_______I System Test
I_______I_______I LINKS 1000 Test Transmission Code
[50] Communicator Format Options (Section 5.8 “Communicator – Reporting Formats”)
Default
02 I___0____I___2____I 1st Phone Number
02 I___0____I____2___I 2nd Phone Number
01 20 BPS, 1400 HZ handshake 04 SIA FSK
02 20 BPS, 2300 HZ handshake 05 Pager Format
03 DTMF CONTACT I.D.
[51] Zone Alarms & Restorals Communicator Call Directions (Section 5.4 “Communicator – Dialing”)
ON I___APA____I 1 1st Telephone Number Disabled
OFF I__APA_____I 2 2nd Telephone Number Disabled
OFF I__APA_____I 3 1st Telephone Number (via LINKS) Disabled
OFF I__APA_____I 4 2nd Telephone Number (via LINKS) Disabled
[52] Zone Tamper Alarms & Tamper Restorals Communicator Call Directions (Section 5.4 “Communicator
– Dialing”)
ON I___APAGADO_____I 1 1st Telephone Number Disabled
OFF I__APA______I 2 2nd Telephone Number Disabled
OFF I__APA______I 3 1st Telephone Number (via LINKS) Disabled
OFF I__APA______I 4 2nd Telephone Number (via LINKS) Disabled
[53] Openings & Closings Communicator Call Directions (Section 5.4 “Communicator – Dialing”)
ON I____A____I 1 1st Telephone Number Disabled
OFF I___A_____I 2 2nd Telephone Number Disabled
OFF I___A_____I 3 1st Telephone Number (via LINKS) Disabled
OFF I___A_____I 4 2nd Telephone Number (via LINKS) Disabled
[54] System Maintenance Alarms & Restorals Communicator Call Directions (Section 5.4 “Communicator
– Dialing”)
ON I__A______I 1 1st Telephone Number Disabled
OFF I__A______I 2 2nd Telephone Number Disabled
OFF I__A______I 3 1st Telephone Number (via LINKS) Disabled
OFF I__A______I 4 2nd Telephone Number (via LINKS) Disabled
[55] System Test Transmissions Communicator Call Directions (Section 5.4 “Communicator – Dialing”)
ON I___A_____I 1 1st Telephone Number (Periodic Test TX and System Test Only) Disabled
OFF I___A_____I 2 2nd Telephone Number (Periodic Test TX and System Test Only) Disabled
OFF I___A_____I 3 1st Telephone Number (via LINKS) (LINKS 1000 Test TX Code Only) Disabled
OFF I___A_____I 4 2nd Telephone Number (via LINKS) (LINKS 1000 Test TX Code Only) Disabled
[60] First Communicator Option Code
ON I___ENC____I 1 Communications Enabled Communications Disabled 5.4
ON I___ENC____I 2 DTMF Dialing Pulse Dialing 5.4
ON I___APA____I 3 Switch to Pulse Dialing on 5th Attempt DTMF Dial For All 8 Attempts 5.4
OFF I__ENCE_____I 4 3rd Phone Number Enabled 3rd Phone Number Disabled 5.6
OFF I__ENCE_____I 5 Alternate Dial (1st and 3rd) Call 1st Number, Backup to 3rd (If programmed) 5.6
OFF I__APA_____I 6 Restorals on Bell Time-out Restorals Follow Zones 5.7.2
[61] Second Communicator Option Code
OFF I___ENC____I 1 Closing Confirmation Enabled Closing Confirmation Disabled 5.7.3
OFF I___ENC____I 2 Opening After Alarm Keypad Open After Alarm Bell Ringback Disabled 5.7.4
Ringback Enabled
OFF I___APA____I 3 Opening After Alarm Bell Opening After Alarm Bell Ringback Disabled 5.7.4
Ringback Enabled
OFF I___A____I 4 Busy Tone Detection Enabled Busy Tone Detection Disabled 5.4
OFF I___A____I 5 Call LINKS As Well As Land Line LINKS is Backup of Land Line(s)
OFF I___A____I 6 SIA Sends Programmed Rep. Codes SIA Sends Automatic Rep. Codes 5.8.3
[62] Communication Variables
Default Section
003 I____0___I___2____I___0____I Swinger Shutdown (Alarms and Rest) (001-014 Transmissions, 000=disabled) 5.16
000 I____0___I___0____I___1____I Transmission Delay (001-255 seconds) 5.17
030 I____0___I___0____I___1____I AC Failure Communication Delay (001-255 minutes) 5.7.7
003 I____0___I___0____I___1____I TLM Trouble Delay (No. of valid checks required - 000-255 x 10s) 5.10
030 I____0___I___0____I___1____I Test Transmission Cycle (001-255 days) 5.12
030 I____0___I___0____I___1____I Delinquency Transmission Delay (000-255 days) 5.7.9
[63] Test Transmission Time of Day (Section 5.12 “Test Transmission”)
Default
9999 I_______I_______I_______I_______I (Valid entries are 0000-2359, 9999 to disable)
[67] LINKS 1000 Preamble (First Telephone Number) (Section 5.23 “LINKS 1000 Cellular Communicator”)
Default
FFFF I_______I_______I_______I_______I (Program all unused digits with Hex F)
[68] LINKS 1000 Preamble (Second Telephone Number) (Section 5.23 “LINKS 1000 Cellular Communicator”)
Default
[69] LINKS 1000 Preamble (Third Telephone Number) (Section 5.23 “LINKS 1000 Cellular Communicator”)
Default
[70] Number of Rings to Answer On (Section 5.9 “Downloading”)
Default
1 2 I_______I_______I (Valid entries are 00-99)
[71] First Downloading Option Code (Section 5.9 “Downloading”)
OFF I___EN____I 1 Downloading Answer Enabled Downloading Answer Disabled
ON I____EN___I 2 User Can Enable DLS Window for One Hour User Cannot Enable DLS Window
OFF I___EN____I 3 Call-Back Enabled Call-Back Disabled
OFF I___EN____I 4 User Initiated Call-up Enabled User Initiated Call-up Disabled
OFF I___EN____I 5 Periodic Download at Test TX Time No Periodic Download
OFF I___EN____I 6 Answering Machine Override Enabled Answering Machine Override Disabled
[72] Downloading Computer’s Telephone Number (32 Digits) (Section 5.9 “Downloading”)
I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I_____I
[73] Downloading Access Code (Section 5.9 “Downloading”)
Default
1575 I_______I_______I_______I_______I Enter 4 Hexadecimal Digits
[74] Panel Identification Code (Section 5.9 “Downloading”)
Default
[75] Answering Machine Double-call Timer (Section 5.9 “Downloading”)
Default
060 I_______I_______I_______I (Valid entries are 001-255 seconds)
[77] [Installer Code] [77] Initiate Local Downloading (PC-LINK) (Section 5.9 “Downloading”)
[79] LINKS 1000 Preamble (Downloading Telephone Number) (Section 5.9 “Downloading”)
Default
Downloading Programming
[87]PC5400 Programming (Printer Module) (Section 5.24 “On-Site Printer”)
[01] Printer Configuration
OFF I________I 1 Printer Enabled Printer Disabled
ON I________I 2 Handshake from Printer No Handshake
OFF I________I 3 80 Column Printer 40 Column Printer
OFF I________I 4 300 Baud Enabled Disabled
OFF I________I 5 1200 Baud Enabled Disabled
ON I________I 6 2400 Baud Enabled Disabled
[05] Printer Language Selection
Default
01 I________I________I (01=English 02=French 03=Spanish)
[88] DLM-1/DLM-4 Support Timers (Section 5.25 “Downlook Video Transmission Module”)
Default
01 I________I________I Number of Pictures (Valid Entries are 01-0
00 I________I________I Delay Before Capture at 100ms increments (Valid Entries are 00-99)
[90] [Installer’s Code] [90] Installer Lockout Enable (Section 5.27 “Installer’s Lockout”)
Enter [90] [Installer’s Code] [90]
[91] [Installer’s Code] [91] Installer Lockout Disable (Section 5.27 “Installer’s Lockout”)
Enter [91] [Installer’s Code] [91]
[92] [Installer’s Code] [92] Module Supervision Reset (Section 2.6 “Supervision”)
[95] [Installer’s Code] [95] Restore ESCORT to Factory Default Programming (Section 5.26 “Resetting
Factory Defaults”)
Enter [95] [Installer’s Code] [95]
[97] [Installer’s Code] [97] Restore PC5400 to Factory Default Programming (Section 5.26 “Resetting
Factory Defaults”)
Enter [96] [Installer’s Code] [96]
[99] [Installer’s Code] [99] Restore PC1575 to Factory Default Programming (Section 5.26 “Resetting
Factory Defaults”)
Enter [99] [Installer’s Code] [99]
fodolocko
solución Mar Nov 20, 2007 12:30 am
BUENAS NOCHES:
ACÁ TE ENVÍO UNA RECOMENDACIÓN QUE PUEDE SERVIRTE.
TUS ZONAS 1 Y 2 QUE SON ZONAS DE RETARDO, POR LO QUE ENTIENDO, LAS PODÉS CONFIGURAR TAMBIÉN COMO ZONAS DE ARMADO FORZADO, ESTO ES, QUE CUANDO TODAS LAS ZONAS ESTÁN CERRADAS Y YA VAS A CONECTAR LA ALARMA, AUNQUE ESTAS SE HABRAN, SEGUIRÁ MARCANDO LISTO EL TECLADO, DE ESTA MANERA PODRÁS CONECTAR SIN "ESTARTE QUEDANDO QUIETO". LAS ZONAS AL FINALIZAR EL TIEMPO DE RETARDO DE ARMADO, QUEDARÁN NORMALES Y CON SU RESPECTIVO RETARDO DE ENTRADA.
LO HACES ASÍ:
1) Entras a programación
2) Vas a la configuración de zonas en (21) para la zona 1
3) Ahí seleccionas la opción 4 (enciendes el LED 4)
4) Presionas [#]
5) Vas a la configuración de la zona 2 en la sección (22)
6) Repites la selección, encendiendo el LED 4
7) Presionas [#] [#]
LO PROBÁS Y A VER QUE TAL.
QUE TENGAS SUERTE.
vicasoto
comentario del autor Mar Nov 20, 2007 9:39 am
Víctor A. Soto sos lo mas gracias por todo es justo lo q yo buscaba el armar forzadoCódigo:
ya pude hacer todo lo q no sabia de esta alarma..... es muy feo cuando tenes el manual de la alarma en ingles  y ademas le falta puntos de programacion... gracias a dios encontre en un server que me pasaron con todo sobre cualquier alarma q exista en el mundo....jiji y ahi estaba mi manual completito... increible no pero ni la pag de dsc lo tenia...gracias..
fodolocko
