| comentario del autor | Mie Sep 03, 2008 12:41 pm | |
| sin valorar | Mie Sep 03, 2008 2:33 pm | |
Báscula Electrónica Denver XL_6100_series_ Portátil multiweight de precisión Instrucciones pre-Calibración Contar con la batería recargada. Revisar fuentes de alimentación. Adaptador DC. Posicionar la unidad nivelada y sin ruido cercano. Mantener el plato sin carga alguna. Contar con pesos patrones exactos (1kg) y (2Kg). Calibración 1. To calibrate the balance, tare or zero the balance with no weight on pan.2. Press and hold down the * key for 3 seconds. The display will read “Unit”.3. Press the * once, the display will now show “CAL”. 4. Press the (cursor abajo) key. The calibration weight of the balance in grams will be displayed.5. Place the correct weight on the balance. After a few seconds the display will flash indicating the value has been accepted. If a fully charged balance loses AC power, it will be able to use its battery backup for 48 hours of weighing. When operating on battery backup the display will flash after 4 minutes if there is no weight change. If left in this mode, the display will continue to flash for 2 additional minutes, after which the balance will shut itself off. David Ortega Chiclayo - Perú Fuente de Datos ::- Denver Instrument GmbH Robert-Bosch-Briete 10 37079 Gottingen Germany Denver_XP_agetronic_.jpg (4,94 KB) ![]() |
