| comentario del autor | Mie Feb 28, 2007 3:04 pm | |
gracias de antemano. |
| solución | Mar Ago 21, 2007 2:00 pm | |
CARDINAL DR20 1. Remove cal screw from side of indicator. 2. Press in and hold cal switch then press on/zero. 3. Display reads int= press print/enter to show current setting then enter again. 4. Keep pressing enter until Lod= appears on display. 5. Press print/enter to show current setting then using on/zero increment flashing digit to desired value and gross to switch to next digit until cal weight is entered. 6. Place the weight entered on platform and press print/enter. The display will show “_ _ _ _” then UnLd. 7. Remove test weights and press enter. 8. Keep pressing enter until donE appears. 9. Press off then on/zero again. Atentamente. Ing. Zavalaga Rivera Dwight Michael Metrologo de Masa de METROIL S.A.C. |
