| comentario del autor | Jue Oct 21, 2004 9:52 am | |
| sin valorar | Vie Oct 22, 2004 10:52 am | |
Multi-Region: Press the Setup button on your remote control Using the onscreen menu, select the Preferences option Press the Still/Step button on your remote control Press the Prev button on your remote control Press the Next button on your remote control You will now enter the hidden setup page, and can change the player to any region or set it to region free. You can also disable Macrovision from this menu If the above fails to work then you may want to try the following: Using the remote press Stop Press 3, 8, 8, 8 and then 3 If the above fails to display a service menu then you may want to try 3, 7, 7, 7 and then 4 or 8 4, 2, 1 and then 3 This will display a system menu where you can select the required region or set the player to region free by selecting 9 To change the video output format between PAL and NTSC: Press the Set-up button on your remote control Press the buttons 7, 2, 5, 5 and 5 on your remote control To see what version of the firmware your player is using: Press the Set-up button on your remote control Press the buttons 1, 2, 3 and 4 on your remote control To convert this player to Multi-Region on older firmware: Press the Set-up button on your remote control Using the on screen menu, select the Preferences option Press the Still/Step button on your remote control Press the Prev button on your remote control Press the Next button on your remote control You will now enter the hidden set-up page, and can change the player to any Region or set it to Region Free. You can also disable Macrovision from this menu Thanks to JCoppock for the information and Chris for the update |
