| comentario del autor | Lun Sep 06, 2004 9:51 pm | |
GRACIAS LAURA |
| comentario | Mar Sep 07, 2004 3:36 pm | |
luismi Region code hack posted by Joe, October 01 2003: Pressing PAUSE(||) and REVERSE(|<<) on the unit and DISPLAY on the remote displays " 1 4C531 ". Pressing PAUSE(||) and REVERSE(|<<) on the unit and MENU on the remote displays " FT01 ". Pressing either |<< or >>| on the remote cycles the display through " FT02 ", " FT03 ". Pressing 0 on the remote changes the display to " FT NG LOAD ". When you press CANCEL on the remote the unit goes into INITIALIZE, the display says "Initialized". My guess is, it looks for some sort of disk to perform initialization of some sort. Good luck. Region code and Macrovision hack posted by john, October 13 2003: Yes, try the following: 1) Pause + open + stop, then press Menu on remote will gives you: 0106 4K453 2) Pause + reverse back, then press Menu on remote will gives you: FT01. Toggle between Forward or Reverse will gives you: FT01, FT02, and FT03. 3) Press Cancel on remote will gives you:initializing on LCD or initialized on tv screen. 4)A number key (press 1 or 0 on remote while displaying 'initializing' - I will post as soon I could reproduce the key sequence) will give you: FT NG SKIP, then every key on both remote and panel will not response. You have to unplug power to reset. Hope someone could make sense of all these. John |
| comentario del autor | Mar Sep 07, 2004 7:20 pm | |
saludos laura |
saludos laura[/quote] |
