| Vie Jun 10, 2005 8:10 pm | ||
http://www.testequipmentdepot.com/hameg/popups/hz65pop.htm Hameg Accessories: HZ65-3 - Component Tester Test voltage:approx. 8.2Vrms Test currents:max. 3.7-37-320mArms Power supply:115V and 230V ±10% Power consumption:max. 4 Watt. Dimensions:125x80x42mm The Component Tester HZ65 permits non-destructive testing of semiconductors, resistors, capacitors, and inductors, either individually or in-circuit. The resulting display on the scope screen will show the characteristic voltage/current diagram of the component under test, enabling its functionality to be interpreted. Two 3-point sockets are provided for testing transistors, permitting selection of any two contacts. Components with larger diameter leads and ICs are connected using two test leads. The test voltage and current are limited, so that no components can be damaged. It is possible to rapidly locate faults in complex circuits by comparing test patterns of a known good circuit and the circuit under test. Before starting the test, all circuits must be disconnected from power to prevent passage of current through any components. It is also very important to disconnect common ground, because any additional connections between components and the tester may cause incorrect pattern display. Connects to all Oscilloscopes. |
