| comentario del autor | Vie May 15, 2009 6:55 pm | |
HP/Compaq name: Livermore-GL6 CPU/Processor Socket: 775 Supports the following processors: Core 2 Duo (Conroe) up to E4300 Pentium D (Presler) up to 960 (3.6 GHz) Pentium 4 (Cedar Mill) up to 661 (3.6 GHz) Celeron D (Cedar Mill) up to 365 (3.6 GHz) Celeron D (Prescott) up to 355 (3.33GHz) Front-side bus (FSB) (Processor Dependent) 800/533 MHz Chipset Intel 945GC BIOS features System BIOS core brand: AMI Keyboard combination to used to enter BIOS: F10 Form factor Micro-ATX: 9.6 in X 9.6 in Memory Dual channel memory architecture Two 240-pin DDR2 DIMM sockets Supported DIMM types: PC2-3200 (400 MHz) PC2-4200 (533 MHz) PC2-5300 (667 MHz, runs at 533 MHz) Non-ECC memory only, unbuffered supports 1 GB DDR2 DIMMs Supports up to 2 GB Expansion slots Two PCI One PCI Express x16 graphics (for graphics cards) One PCI Express x1 (for cards such as network, sound, tv-tuner) Video graphics Integrated graphics using Intel GMA 950 Use up to 256MB of PC memory (with 512MB or more total PC memory) Also supports PCI Express x16 graphics cards NOTA: Either integrated graphics or the PCI Express x16 slot are usable at one time; they are not usable concurrently. Parallel ATA One 40-pin UltraDMA 100/66/33 connector Supports PIO, multi-word DMA modes Supports two PATA disk drives on one PATA ribbon cable (two drives total) Serial ATA Two SATA connectors: SATA1 = Black SATA2 = White NOTA: Each SATA connector is the same color across different manufacturers. Supports 1 SATA-150 or SATA-300 disk drive on each SATA connector Speed up to 1.5Gb/sec or 3.0Gb/sec, complying with SATA 1.0 and SATA 2.0 specifications NOTA: The faster rate of 3.0Gb/sec requires that both the hard drive and the motherboard support it. If one or the other does not support 3.0 Gb/sec, the PC negotiates down to the slower 1.5 Gb/sec. Onboard audio 6-channel high-definition audio Audio CODEC: ALC888 Onboard LAN PCI Realtek RTL8201E 10/100Mbps Y esta es una imagen de la Torre:https://h20285.www2.hp.com/estore/images... Esta es otra: http://bizsupport1.austin.hp.com/bc/imag... Les agradecería de corazón si me lo encontraran, por tal driver no puedo acceder a Internet. Gracias y Ojalá tengan mas suerte que yop. =) |
