Como hago una compilacion? Que debo hacer?
comentario del autor Dom Sep 05, 2004 8:52 pm
Hola a todos, esto lo colgue aqui en el foro general porque en realidad no tiene mucha importancia. Si quieren perder el tiempo un rato pues leanlo y aconsejenme.
Pues resulta que me baje una distro de debian y la instale hasta que aparece kde, todo el entorno gráfico, en fin todo bien.
Empiezan los problemas, no se como instalar drivers, atranscribo un .tx que viene con los drivers de la placa de red encore nic-1
** Linux Driver support linux kernel version 2.2.x and 2.4.x
Introduction:
The instructions listed below are for linux driver installation. You must
compile the source code to generate rhinefet.o and use insmod command to
insert rhinefet.o as module.
Contents of the Subdirectory:
linux.txt This file.
rhine.h The linux core driver header file
rhine_main.c The linux core driver source code file
rhine_proc.c The linux core driver source code file
rhine_wol.c The linux core driver source code file
Makefile Makefile for generating driver object file
rhine_vmns.c The vmns driver support source file
rhine_vmns.h The vmns driver support header file
rhine_cfg.h The vmns driver support header file
vmns_drv.h The vmns driver support header file
Kernel Supported
This driver support linux kernel version 2.2.x and 2.4.x now.
Installation
Please enter the following commands at the UNIX prompt. Remember, UNIX is
case sensitive.
1) Create a temporary directory:
mkdir /temp
2) Change to the temporary directory:
cd /temp
2) Copy driver (rhinefet.tgz) from DOS disk, (mcopy below is one tool in
mtools, if you didn't install mtools, you can type
'mount -t msdos /dev/fd0 /mnt' and use 'cp /mnt/rhinefet.tgz /temp'
command to copy the driver to the temporary directory):
mcopy a:rhinefet.tgz .
3) untar the archive file:
tar xzvf rhinefet.tgz
cd rhinefet
4) Compile the driver source files and it will generate rhinefet.o, (como carambas hago esto?) and
copy it to correct driver installation path (The installation directory
is different in different kernel versions. In 2.4.x kernel, the path is
/lib/modules/KERNEL_VERSION/kernel/drivers/net/, and in 2.2.x kernel,
the path is /lib/modules/KERNEL_VERSION/net/, the KERNEL_VERSION (see
above) means the kernel version of your Linux distribution. If you don't
know your kernel version , please run 'uname -r' command in command
line. The kernel version will look like '2.2.16', '2.4.2-2smp' etc.) :
make install
5) Check configuration file (/etc/modules.conf or /etc/conf.modules,it
depend on your Linux distribution) for loading kernel modules. Make sure
there is the following content in the configuration file, where # is
interface number (eg: alias eth0 rhinefet):
alias eth# rhinefet
6) Reboot now:
shutdown -r now
7) Install your driver module (If the driver module is in the wrong place,
an error message will appear, and say that can't find the driver
module):
insmod rhinefet
Cool Use ifconfig command to assign the IP address, where # is network
interface number:
ifconfig eth# <IP>
9) Check the interface works:
ping <remote_host_IP>
Bien esto tratando de conectarla a internet a travez de una lan.
Enseguida de esto me las tendre que ver con una impresora epson stylus c63 conectada en otro equipo en la red.
Luego, enseguida del arranque me sale un cartelito que dice que el sonido no pudo ser iniciado, eso no me importa mucho supongo que sacando ese paquete que no inicia y poniendo el driver correcto.
Tampoco puedo ver las unidades de cd ni floppy instalados, quice abrir unos archivos de word, exel y powerpoint, por probar compatibilidades y no encontre por ningun lado las unidades.
En fin me estoy dvirtiendo, pero esto me ocaciona tener una máquina parada y yo creo que si para el martes no arreglo lo de la red, impresora y documentos le reinstalo windows y me olvido de debian, ademas de que mis clientes se sentiran un poco incomodos con linux y mas aun si no se decirles de que se trata............
Juan1972
comentario Dom Sep 05, 2004 10:38 pm
Hola Juan.
Sin ofender a los debianitas........
Si tenés ánimos de aprender Linux, Debian es bastante dura para comenzar.
Es de esas distribuciones que tenés que configurar gran parte del hardware a pura mano.
Es cierto que se obtienen buenos resultados (eso dicen los que saben), pero para la novatada en Linux nada mejor que empezar con Mandrake, Fedora Core, SuSE o Knoppix (que está basado en Debian).
Detectan, configuran e instalan el hardware automáticamente.
Yo me considero novato en Linux, pero creo que por ej. con Fedora encontré una distribución a mi medida.
Y día a día trato de hacerme más amigo de la consola, que ahí es donde "cuentan" se experimentan las mayores satisfacciones.
P.D.: lamento no haber podido ayudarte, pero te dejo una observación mía. Wink
SALU2.-
El-NoXa
comentario del autor Lun Sep 06, 2004 2:03 pm
jeje esperaba algo como eso, ya estoy trabajando por el lado de fedora. En serio que ya busque y busque y no encontre algo que pudiera entender. Imagino que en el archivito ese llamado makefiler esta la clave, pero no la encuentro. Bueno leere algo de instalación de fedora y lo que pueda mas. Los detalles de afinación sobre la marcha. Por lo mientras tengo unas 6 hjoras para estudiar....... Razz
Gracias. Wink
Juan1972
comentario del autor Mar Sep 07, 2004 9:24 pm
ya baje fedora, ahora no puedo hacerlo arrancar, ya me copie la imagen que esta dentro del cd1 que se llama boot y tampoco. Ni modo sera para la otra..............
Juan1972
comentario Sab Sep 25, 2004 2:09 pm
Hola Juan, hubieras puesto este tema en zona Linux, ahora lo muevo para ahí.
El problema que estabas teniendo en Debian no es tan complicado, y hoy día ya no es eso de que es una distribución compicada. Con el perdón del NoXa (perdón NoXa Wink ) Fedora es una chanchada y no te estimula a aprender (si eso es lo que querés hacer con Linux), por mi lado opino todo lo contrario, para aprender es mejor que tengas que configurar todo a mano, y si llegás a un grado de frustramiento mayor, que te esté por hacer abandonar la idea de usar Linux recién ahí pasate a una distro más light.
La compilación, era simplemente hacer "./configure" y luego "make".
Por las dudas te aclaro qué es compilar, compilar es traducir el código fuente a código de máquina. El código fuente es el que escriben y entienden los programadores, y está escrito en lenguajes muy parecidos al inglés, el código de máquina es el que interpreta el procesador con instrucciones del estilo mover tal valor a tal ubicación de memoria, etc...
Compilar no es un misterio. Como por lo general en Linux tenés a tu alcance el código fuente del software (es por esto que es de Código Abierto) es muy natural que las cosas se distribuyan en código fuente para que lo compiles a tu gusto. Haciendo configuraciones que luego de compilado el programa o driver no podrías hacer.
Lo que recibes de los drivers es el código fuente, un montón de archivos .c y .h. Los pasos necesarios para compilar este código fuente están escritos en un archivo llamado Makefile, esto es a lo que te referías, y el comando make lee el Makefile del directorio actual por instrucciones sobre cómo compilar los drivers.
Eso es mas o menos someramente todo.
Saludos!
mauricio
comentario Sab Sep 25, 2004 5:45 pm
mauricio escribió:Con el perdón del NoXa (perdón NoXa Wink ) Fedora es una chanchada y no te estimula a aprender (si eso es lo que querés hacer con Linux)
Será chancha pero no tuve más noticias tuyas sobre si te pasaste de nuevo a Debian o no.
Yo soy de los que piensa que para los que recién empiezan distribuciones como Fedora Core, Mandrake, SuSE o Knoppix si estimulan a aprender aunque no se tenga que configurar todo a mano porque el sistema se encarga de eso.
No veo la necesidad de "sangrar" como un asno cuando no podés hacer funcionar tu impresora o escáner en Linux teniendo la posibilidad de que con solo instalarle el driver correcto (enciertas ocasiones) ya esté listo para funcionar.
Esa es la filosofía de Microsoft ----> Plug & Play y por ahora Linux anda medio lejos de esa perspectiva.
Sobre compilar basta con pegarle una leidita al readme.txt que traen los archivos y ahí seguro indican los clásicos comandos que te comentó mauricio (./configure && make && make install)-
El-NoXa
comentario Sab Sep 25, 2004 7:13 pm
Mirá, estoy escribiendo desde un amáquina con Windows XP así que si hablara por el ejemplo no llegaríamos muy lejos Wink Pero es la máquina de mi hermano, eso me excusa Smile
Me estoy por mudar, estoy esperando el release de Debian Sarge, y además tiengo diez mil cosas andando arriba de la distro, cambiarme es un parto Sad
Te cuento la última, que me hizo renegar, que fué la gota que colmó el vaso: estaba trabajando en un documento, súper importante, con OpenOffice arriba del odioso Fedora core 2, y cuando fuí a guardarlo... la muy cochina se colgó. No habían archivos temporales y perdí el trabajo de un día. ¡Que me parta un rayo! Y que me perdonen pero no solo me pareció malo, me hizo acordar los peores tiempos de Windows, digamos los de Windows ME, porque XP no es tan inestable como fedora, por lo tanto, antes de odiar al pingüino prefiero amarlo en otra de sus distribuciones, porque la verdad que fedora me lo hace pensar dos veces. "Se la vi!" dijo el francés, y mejor sangrar que reventar como un sapo!!!!
Very HappyVery HappyVery Happy ¿Medio cargadito eh? Bueno, fedora me enerva. Yo ya he comentado por ahí, en la lista del UYLUG, que tengo una teoría de la conspiración que dice que Microsoft compró la mayoría de las acciones de Red Hat (no nos olvidemso que Red Hat es una corporación que cotiza en bolsa) y está tratando de destruír al pingüino por dentro. Macabro, fantasioso, pero si realmente hubiera sido así esta sería exactamente la forma de proceder que tomarían para destruír al pingüino por dentro, hacer que la distro más usada sea patética.
Saludos!!!
mauricio
comentario Dom Sep 26, 2004 4:33 pm
Mira yo uso fedora y la verdad es que estoy muy lejos de pensar como mauricio.
Claro que red hat cotiza en bolsa pero pero fedora es del mundo solo tiene el apoyo de red hat en pocas cosas.
creo que si te pones en esquicito en fedora tbn podes renegar bastante (hablo de configuracion de server, y hasta un escritorio de una persona comun que le interesa un poco la informatica). Obiamente tbn tenes la opcion de configurar todo mediante asistentes que le quita un poquito el gusto pero si lo haces bajo consola las cosas terminan casi a la par y obiamente logras un mejor rendimiento que con un asistente.
A y de lo que hablaba juan tenes que leer bien los pasos para instalar porque para cada soft va un procedimiento distinto, puede ser primero ./cofigure
make
make install
ademas de tener opciones como --prefix --force, etc
Suerte
Saluda atte ema
ema
comentario Dom Sep 26, 2004 8:11 pm
Creo que sin necesidad de menospreciar ninguna distro, la clave para aprender a manejar bien cualquier sistema linux es la shell. Una vez dominado el entorno de comandos, usar x distro es lo de menos. Yo estoy iniciando, y he usado mandrake redhat y fedora y no me tengo que quejar del software, el problema muchas veces es el hardware sobre el cual corre, de eso no hay que olvidarse ( una maquina que tiene un daño en el micro, igual se pega con win o con linux )
mamador
comentario Dom Sep 26, 2004 10:43 pm
mauricio escribió:¿Medio cargadito eh? Bueno, fedora me enerva
JUAJUAAAA!
Sí......supongo que debe ser doloroso.
Pero bueh, yo también estoy esperando que los debianitas saquen Sarge a la calle para poder probarla algún día.
Me dolería porque ya llegué a un punto con Fedora en el que tengo el sistema bastante afinadito aunque me sigo pegando cada cabezazo con algunos temas que a veces me dan ganas de mandar todo al carajo.
Muy buena la frase del sapo Mauri!!!!!! Wink Very Happy
El-NoXa
comentario Dom Sep 26, 2004 11:31 pm
Está bien lo que dicen, en definitiva todos son Linux y se pueden afinar a placer. Lo que me cuesta a mí de Fedora es que para afinarlo hay que tener la santa paciencia y habría que darlo vuelta de patas arriba. También hay que ver que tiene mucho software, muchísimo, que lo instala hasta en las instalaciones mínimas, y que además tiene mucho software inestable. No vamos a comparar un fedora que por ejemplo viene con X.org algo super recontra nuevo y poco probado contra un Debian Sarge, que no salió pero va a venir con un XFree 4.3 bien patchedo. Unos apuestan a tener todos los chiches nuevos y los otros a tener la mayor estabilidad posible, son dos formas de armar la distro muy diferentes que producen dos resultados muy diferentes y para diferentes intereses.
Salutes!
mauricio
comentario del autor Lun Sep 27, 2004 4:12 pm
Vaya, vaya.... ya terminaron de discutir? Por cierto algo ilustrativa...... chavos solo me divertía, no pierdan su tiempo conmigo. Bueno tengo woody completa son 7 cd`s, si? y fedora core2, por el momento no tengo en que probar nuevamente. Le estoy hechando el ojo a un PII a ver si resiste y trataré de hacer funcionar fedora.
Bueno en esta discusión aprendí que se puede discutir sin calentarse y que podemos estar de acuerdo en que no siempre estaremos de acuerdo.
Gracias.
Juan1972
comentario Lun Sep 27, 2004 7:47 pm
Por supuesto que se puede debatir un tema sanamente y con buenos modales como lo han hecho todos los que participamos.
Eso demuestra que aunque exista una diversidad de opiniones en nuestra comunidad nos podemos tratar con respeto. Very Happy
El-NoXa
