| comentario del autor | Jue Jul 07, 2005 7:19 pm | |
pero tengo el siguiente problema, me muestra el siguiente error y no se como corregirlo. Tengo los source files. x si acaso: ------------------------------------------------------------------------------------- See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IO.EndOfStreamException: Unable to read beyond the end of the stream. at System.IO.__Error.EndOfFile() at System.IO.BinaryReader.FillBuffer(Int32 numBytes) at System.IO.BinaryReader.ReadInt32() at EMFSpoolfileReader.EMFSpoolfileReader.GetTruePageCount(String SpoolFilename) at EMFSpoolViewer.SpoolFileForm.MenuItem_File_Open_Click(Object sender, EventArgs e) at System.Windows.Forms.MenuItem.OnClick(EventArgs e) at System.Windows.Forms.MenuItemData.Execute() at System.Windows.Forms.Command.Invoke() at System.Windows.Forms.Control.WmCommand(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 1.0.3300.0 Win32 Version: 1.0.3705.0 CodeBase: file:///c:/windows/microsoft.net/framework/v1.0.3705/mscorlib.dll ---------------------------------------- EMFSpoolViewer Assembly Version: 1.0.1980.19643 Win32 Version: 1.0.1980.19643 CodeBase: file:///C:/Documents%20and%20Settings/marcocoto/Desktop/spool%20files/spool/EMFSpoolViewer.exe ---------------------------------------- System.Windows.Forms Assembly Version: 1.0.3300.0 Win32 Version: 1.0.3705.0 CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.3300.0__b77a5c561934e089/system.windows.forms.dll ---------------------------------------- System Assembly Version: 1.0.3300.0 Win32 Version: 1.0.3705.0 CodeBase: file:///c:/windows/assembly/gac/system/1.0.3300.0__b77a5c561934e089/system.dll ---------------------------------------- Microsoft.VisualBasic Assembly Version: 7.0.3300.0 Win32 Version: 7.00.9466 CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.3300.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll ---------------------------------------- EMFSpoolfileReader Assembly Version: 1.1.1980.19643 Win32 Version: 1.1.1980.19643 CodeBase: file:///C:/Documents%20and%20Settings/marcocoto/Desktop/spool%20files/spool/EMFSpoolfileReader.DLL ---------------------------------------- System.Drawing Assembly Version: 1.0.3300.0 Win32 Version: 1.0.3705.0 CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.3300.0__b03f5f7f11d50a3a/system.drawing.dll ---------------------------------------- System.Xml Assembly Version: 1.0.3300.0 Win32 Version: 1.0.3705.0 CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.3300.0__b77a5c561934e089/system.xml.dll ---------------------------------------- ************** JIT Debugging ************** To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog. ------------------------------------------------------------------------------------- Gracias Marco Coto marcot50@hotmail.com |
