Kenwood TK 805D necesito manual de servicio
comentario del autor 15 Jun 2007 03:10
Responder citando
Hola a todos, alguien sabe dode puedo conseguir el manual de usuario del Kenwood TK805D??
desde ya muchas gracias por las rtas Wink
Título editado
Consulta aquí
solución 10 Jul 2007 19:44
Responder citando
Kenwood TK-805D Operation
Controls:
• I/O - On/Off Switch
• - Monitor Mode (Squelch open)
• AUX - Auxiliary Mode
• REC -
• SCAN - Scan Mode
• D/A - Delete / Add
• Volume - Volume Control
• - Selects Channel
Display:
• CH x - Channel x selected
• TA x - Channel x in Turn-Around mode (Simplex)
• SCAN - In active scan mode
• SC x - In scan mode, but stopped on channel x
• AUX - This channel has AUX (Simplex) mode enabled
• ADD - This channel is in scanning table
Kenwood TK-805D Setup
To enter setup mode:
1. Turn radio on while holding AUX and SCAN
2. Unit will beep 3 times.
3. Use PTT to save selection.
Function Display Selections
Band Range 450.000 150/250/350/450 MHz
Time Out Timer t Off Off, 30, 60, 90, 120, 180 Seconds
Busy Channel Lockout b On On - Enabled
Off - Disabled
Del/Add Condition dA On On - User selectable
Off - Fixed
Mic Hook Operation H On On - Scan on hook, PTT off hook, Monitor off Hook
Off - Scan disabled, PTT on or Off Hook, No off Hook Monitor
Priority Channel P Fl Fl - Fixed Priority
US - User Selectable
Monitor Switch En On On - Press to disable decode, hold to disable squelch
Off - Press to disable squelch
Off-Hook Monitor dE Off On - No Off Hook Monitor
Off - Monitor Off Hook *
Off-Hook Scan SC On On - Off Hook Scan
Off - Scan On-Hook Only
* Off Hook Monitor (dE Off) is only enabled when On-Hook Scan (SC Off) is Selected.
When you reach END, you can power the radio off.
Kenwood TK-805D Channel Programming
Note: While in the programming mode, switches have these functions:
• - Hold to step forward and backward thru programming (Use to move).
• AUX - Hold for 1MHz step rate.
• REC - Turns AUX indicator On/Off (Auxiliary mode enabled/disabled).
• SCAN - Toggles between 10 KHz and 12.5 KHz frequency steps.
• D/A - Turns ADD indicator On/Off (In/Out of scanning table).
• - Change Selection
To enter programming mode:
1. Press turn radio on while holding AUX and D/A
2. Unit will beep 4 times.
Function Options
RX Frequency 390.000 to 490.000 MHz (Hold AUX for 1 MHz steps)
RX Tone type Soff - No tone
S dt - Digital PL
S t - PL Tone
RX PL frequency 67.0 to 250.3 Hz (Digital: 000 - 777, SCAN inverts)
(Hold REC for 10 Hz steps, Hold AUX for 1 Hz steps)
TX Frequency 390.000 to 490.000 MHz (Hold AUX for 1 MHz steps)
TX Tone type Soff - No tone
S dt - Digital PL
S t - PL Tone
TX PL frequency 667.0 to 250.3 Hz (Digital: 000 - 777, SCAN inverts)
Repeat above steps for all channels. The channel number is shown in the lower right corner.
Note: A display of -.--- Indicates the channel is not programmed.
When channel 16 has been programmed, continue with settings below:
Aux selection tA tA - Talk-Around (Simplex)
DRS - Digital Recording System
2tonE - 2 Tone sequential decode
dt - DTMF Decode
Scan Resume RX rA 3.0 1.0 to 8.0 Seconds
Scan Resume TX rb 3.0 1.0 to 8.0 Seconds
Fixed Priority Channel P - P - No priority Channel
P xx - Channel xx is priority channel
Lookback A La 1.0 1.0 to 8.0 Seconds
Loopback B Lb 1.0 1.0 to 8.0 Seconds
Revert Channel* CA cH sT - Selected Channel (Last channel selected before SCAN pressed)
P - Priority Channel
CA - Last RX channel used
US - Last TX channel used
* Revert channel is the channel the transmitter will switch to automatically, when PTT is pressed during off-hook scan.
Note: The only way to clear a channel is to clear memory.
Clear Memory
Power radio on while holding AUX + SCAN + D/A
Espero ke te sirva,cualkier cosa a mi correo paramediko@gmail.com
