| comentario del autor | Mie Feb 06, 2008 4:03 pm | |
| solución | Mie Feb 06, 2008 6:13 pm | |
Xerox / Phaser 6120 Service Menu Entering the Service Menu Note: Ensure appropriate security for the Service menu entry procedure. It should NEVER be given to any unauthorized person. 1. Select SERVICE MENU and press the Menu Select key. 2. Press the Menu Select key twice. Using the Arrow keys, enter the password. (The password is “XRX6120N.” The password is case sensitive.) 3. Press the Menu Select key and right arrow key. Exiting 1. Press UP key to return to the initial screen. List of Service Menu Functions SERVICE MENU I SERVICE PASSWORD I RESET COUNTERS I TRANSFER BELT FUSER UNIT Settings/Adjustments in Service Menu FunctionsI RESET COUNTERS: a-TRANSFER BELT Function:==Resets the counter value of the Transfer Belt Unit. Use ==To reset the Transfer Belt Unit counter when the Transfer Belt Unit is replaced. Setting / procedure== 1. Enter the Service menu. 2. Select “TRANSFER BELT.” 3. Select “YES” and press the Menu Select key. b-FUSER UNIT Function== Resets the counter value of the Fusing Unit. Use ==To reset the Fusing Unit counter when the Fusing Unit is replaced. Setting /procedure== 1. Enter the Service menu. 2. Select “FUSER UNIT.” 3. Select “YES” and press the Menu Select key. suerte OK |
