Tienda | Foros | Blogs | EN |
Power supply for asrock K8Upgrade-VM800 motherboard
good that power source needs an asrock K8Upgrade-VM800 motherboard since I have a 500 watt but it does not turn on (THE SOURCE OF POWER IS FUNCTIONAL) thanks
3 Soluciones propuestas
Here you can calculate the power source according to your board and internal peripherals.
https://outervision.com/power-supply-calculator
All you have to do is enter the data of your computer.
look at any motherboard that is in conditions will boot up with a source of 200 w generica, in the manual tells you what you consume (which is little), what you have to try is with the minimum a ram, processor and a hard drive and see how it responds, if the 500w is fine (make sure it is okay, I would try another source) should turn on without problems
the source is more than good, now that it does not mean that this functional, maybe the values ​​are not correct, I've seen that.
