Solo faltan 52.398 soluciones y llegaremos a los 500.000 articulos que no se convirtieron en CHATARRA o BASURA!!!
Bus PCI 0, dispositivo 31, función 3
hola, quisiera me ayudaran a resolver esto:
el administrador de dispositivos dice que no están instalados los controladores para este dispositivo, Bus PCI 0, dispositivo 31, función 3
estuve navegando y me confundí mas de lo que me aclaré.
les dejo los datos de mi pc
System Information
Time of this report: 9/14/2012, 21:46:52
Machine name: OPERADOR-
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.120504-1619)
Language: Spanish (Regional Setting: Spanish)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz (2 CPUs)
Memory: 2048MB RAM
Page File: 545MB used, 3397MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 9500 GT
Manufacturer: NVIDIA
Chip type: GeForce 9500 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0640&SUBSYS_0000196D&REV_A1
Display Memory: 1024.0 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor: Monitor Plug and Play
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0012.5896 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 7/9/2010 19:38:00, 6343040 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VD no disponible
Mini VD nv4_mini.sys
Mini VDD Date: 7/9/2010 19:38:00, 10604128 bytes
Device Identifier: {D7B71E3E-4500-11CF-D56D-0C2000C2CB35}
Vendor I 0x10DE
Device I 0x0640
SubSys I 0x0000196D
Revision I 0x00A1
Revision I 0x00A1
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware I HDAUDIO\FUNC_01&VEN_10EC&DEV_0662&SUBSYS_18493662&REV_1001
Manufacturer I 1
Product I 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.6602 (English)
WHQL Logo'd: Yes
Date and Size: 3/27/2012 17:03:36, 6100072 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Mapeador Microsoft MIDI [Emulado], Hardware (Not Kernel Mode), Output, No DLS, Internal
Sint. SW de tabla de ondas GS [Emulado], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller I n/a
Vendor/Product I n/a
FF Driver: n/a
Device Name: Teclado
Attached: 1
Controller I n/a
FF Driver: n/a
Device Name: 2.4G Wireless Mouse
Attached: 1
Controller I 0x0
Vendor/Product I 0x0458, 0x00E3
FF Driver: n/a
Attached: 1
Controller I 0x0
FF Driver: n/a
Attached: 1
Controller I 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ Concentrador raíz USB
| Vendor/Product I 0x8086, 0x27CB
| Matching Device I usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 00:15:38, 59520 bytes
| Driver: usbd.sys, 8/24/2001 04:00:00, 4736 bytes
+-+ Dispositivo de interfaz humana USB
| | Matching Device I usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidusb.sys, 4/14/2008 00:15:28, 10368 bytes
| | Driver: hidclass.sys, 4/14/2008 00:15:28, 36864 bytes
| | Driver: hidparse.sys, 4/14/2008 00:15:24, 24960 bytes
| | Driver: hid.dll, 4/14/2008 07:48:22, 20992 bytes
| +-+ Dispositivo compatible con HID
| | | Matching Device I hid_device
| +-+ Dispositivo de control del consumidor compatible con HID
| | | Matching Device I hid_device_up:000c_u:0001
| | | Driver: hidserv.dll, 4/14/2008 07:48:22, 21504 bytes
| +-+ Mouse compatible con HID
| | | Matching Device I hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 4/14/2008 07:19:14, 23552 bytes
| | | Driver: mouhid.sys, 9/16/2006 19:36:18, 12416 bytes
Gameport Devices
PS/2 Devices
+ Teclado estándar de 101/102 teclas o Microsoft Natural PS/2 Keyboard
| Matching Device I *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 07:22:36, 53504 bytes
| Driver: kbdclass.sys, 4/14/2008 07:25:10, 25088 bytes
+ Controlador de teclado de Terminal Server
| Matching Device I root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 07:49:44, 40840 bytes
+ Controlador de mouse de Terminal Server
| Matching Device I root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Módem estándar
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Conexión de área local - IPv4 -
DirectPlay8 TCP/IP Service Provider: speepy - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 Kbits/seg
Voxware SC06 6,4 Kbits/seg
Voxware SC03 3,2 Kbits/seg
MS-PCM 64 Kbits/seg
MS-ADPCM 32.8 Kbits/seg
Microsoft GSM 6.10 13 Kbits/seg
TrueSpeech(TM) 8.6 Kbits/seg
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 117.0 GB
Total Space: 305.2 GB
File System: NTFS
Model: WDC WD3200AAKS-00UU3A0
Drive: E:
Model: ATAPI iHAS124 Y
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (Spanish), 4/14/2008 00:10:48, 62976 bytes
Drive: F:
Model: DTSOFT Virtual CdRom Device
Drive: G:
System Devices
Name: Controladora estándar PCI IDE de doble canal
Device I PCI\VEN_8086&DEV_27DF&SUBSYS_27DF1849&REV_01\3&11583659&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (Spanish), 4/14/2008 00:10:30, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 00:10:32, 96512 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (Spanish), 8/24/2001 04:00:00, 3456 bytes
Name: Controladora de bus SM
Device I PCI\VEN_8086&DEV_27DA&SUBSYS_27DA1849&REV_01\3&11583659&0&FB
Driver: n/a
Name: Controlador de bus de Microsoft UAA para High Definition Audio
Device I PCI\VEN_8086&DEV_27D8&SUBSYS_36621849&REV_01\3&11583659&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/13/2008 22:06:06, 144384 bytes
Name: Puente PCI estándar de PCI a PCI
Device I PCI\VEN_8086&DEV_27D2&SUBSYS_00000000&REV_01\3&11583659&0&E1
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (Spanish), 4/14/2008 07:28:42, 68992 bytes
Device I PCI\VEN_8086&DEV_27D0&SUBSYS_00000000&REV_01\3&11583659&0&E0
Name: Controlador de host de PCI a USB mejorado
Device I PCI\VEN_8086&DEV_27CC&SUBSYS_27CC1849&REV_01\3&11583659&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (Spanish), 4/14/2008 07:48:46, 77824 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 07:48:22, 7168 bytes
Name: Controladora de host PCI a USB estándar universal
Device I PCI\VEN_8086&DEV_27CB&SUBSYS_27CB1849&REV_01\3&11583659&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 20608 bytes
Device I PCI\VEN_8086&DEV_27CA&SUBSYS_27CA1849&REV_01\3&11583659&0&EA
Device I PCI\VEN_8086&DEV_27C9&SUBSYS_27C91849&REV_01\3&11583659&0&E9
Device I PCI\VEN_8086&DEV_27C8&SUBSYS_27C81849&REV_01\3&11583659&0&E8
Device I PCI\VEN_8086&DEV_27C0&SUBSYS_27C01849&REV_01\3&11583659&0&FA
Name: Puente PCI ISA estándar
Device I PCI\VEN_8086&DEV_27B8&SUBSYS_00000000&REV_01\3&11583659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (Spanish), 4/14/2008 07:24:48, 37760 bytes
Device I PCI\VEN_8086&DEV_2771&SUBSYS_00000000&REV_02\3&11583659&0&08
Name: Puente PCI de CPU host estándar
Device I PCI\VEN_8086&DEV_2770&SUBSYS_00000000&REV_02\3&11583659&0&00
Driver: n/a
Name: Puente PCI Intel(R) 82801 - 244E
Device I PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_E1\3&11583659&0&F0
Name: Controlador de host mejorado USB VIA
Device I PCI\VEN_1106&DEV_3104&SUBSYS_31041106&REV_65\4&CF81C54&0&12F0
Name: Controlador de host universal USB VIA Rev 5 o posterior
Device I PCI\VEN_1106&DEV_3038&SUBSYS_30381106&REV_62\4&CF81C54&0&11F0
Device I PCI\VEN_1106&DEV_3038&SUBSYS_30381106&REV_62\4&CF81C54&0&10F0
Name: Realtek RTL8102E Family PCI-E Fast Ethernet NIC
Device I PCI\VEN_10EC&DEV_8136&SUBSYS_81361849&REV_02\4&38D2602C&0&00E1
Driver: C:\WINDOWS\system32\DRIVERS\Rtenicxp.sys, 5.698.0701.2008 (Spanish), 7/1/2008 11:27:44, 108800 bytes
Driver: C:\WINDOWS\system32\RtNicProp32.dll, 1.01.0716.2008 (English), 7/22/2008 00:14:10, 9728 bytes
Name: NVIDIA GeForce 9500 GT
Device I PCI\VEN_10DE&DEV_0640&SUBSYS_0000196D&REV_A1\4&24AE49A5&0&0008
Driver: C:\Archivos de programa\NVIDIA Corporation\Drs\dbInstaller.exe, 6.14.0012.5896 (English), 7/9/2010 19:38:00, 139776 bytes
Driver: C:\Archivos de programa\NVIDIA Corporation\Drs\nvdrsdb.bin, 7/9/2010 19:38:00, 232968 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0012.5896 (English), 7/9/2010 19:38:00, 10604128 bytes
Driver: C:\WINDOWS\system32\OpenCL.dll, 1.00.0000.0000 (English), 7/9/2010 19:38:00, 61440 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0012.5896 (English), 7/9/2010 19:38:00, 6343040 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0012.5896 (English), 7/9/2010 19:38:00, 1388544 bytes
Driver: C:\WINDOWS\system32\nvcompiler.dll, 6.14.0012.5896 (English), 7/9/2010 19:38:00, 10260480 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0012.5896 (English), 7/9/2010 19:38:00, 4595712 bytes
Driver: C:\WINDOWS\system32\nvcuvenc.dll, 6.14.0012.5896 (English), 7/9/2010 19:38:00, 2506344 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0012.5896 (English), 7/9/2010 19:38:00, 2914408 bytes
Driver: C:\WINDOWS\system32\nvdata.bin, 7/9/2010 19:38:00, 2195030 bytes
Driver: C:\WINDOWS\system32\nvinfo.pb, 7/9/2010 19:38:00, 7959 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0012.5896 (English), 7/9/2010 19:38:00, 13549568 bytes
Driver: C:\Archivos de programa\NVIDIA Corporation\Uninstall\nvdisp.nvu, 7/9/2010 19:38:00, 25836 bytes
Driver: C:\Archivos de programa\NVIDIA Corporation\Uninstall\nvudisp.exe, 1.10.0062.0040 (English), 7/9/2010 19:38:00, 604776 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.09.0022.0107 (English), 7/9/2010 19:38:00, 236136 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.09.0022.0107 (English), 7/9/2010 19:38:00, 236136 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/24/2001 04:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/24/2001 04:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/24/2001 04:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/24/2001 04:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/24/2001 04:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/24/2001 04:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 Spanish Final Retail 8/24/2001 04:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 229888 bytes
dpmodemx.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 24064 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/24/2001 04:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 57856 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:56 29696 bytes
dpnsvr.exe: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:56 18432 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:46:34 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:46:34 3072 bytes
dpvoice.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 213504 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:56 83456 bytes
dpvvox.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 116736 bytes
dpvacm.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 60928 bytes
dpserial.dll: 5.00.2134.0001 Spanish Final Retail 8/24/2001 04:00:00 54032 bytes
dinput.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 167936 bytes
dinput8.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 190976 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/24/2001 04:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 Spanish Final Retail 8/24/2001 04:00:00 395264 bytes
joy.cpl: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:49:18 70144 bytes
gcdef.dll: 5.01.2600.0000 Spanish Final Retail 8/24/2001 04:00:00 77824 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:34 35328 bytes
dsound.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 74752 bytes
dmusic.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 82432 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 8/9/2012 13:17:01 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 8/9/2012 13:16:55 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 8/9/2012 13:16:56 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 8/9/2012 13:16:56 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 8/9/2012 13:16:57 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 8/9/2012 13:16:57 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 8/9/2012 13:16:58 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 8/9/2012 13:16:58 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 8/9/2012 13:16:59 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 8/9/2012 13:16:59 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 8/9/2012 13:17:01 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 8/9/2012 13:17:01 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 8/9/2012 13:17:02 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 8/9/2012 13:17:02 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 8/9/2012 13:17:02 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 8/9/2012 13:17:00 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 8/9/2012 13:17:00 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 8/9/2012 13:17:00 223232 bytes
dx7vb.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 619008 bytes
dx8vb.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 2113536 bytes
mfc40.dll: 4.01.0000.6151 English Beta Retail 9/18/2010 03:53:18 954368 bytes
mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 10:33:28 978944 bytes
wsock32.dll: 5.01.2600.5512 Spanish Final Retail 4/14/2008 07:48:48 25600 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 07:48:20 70656 bytes
devenum.dll: 6.05.2600.5512 Spanish Final Retail 4/14/2008 07:48:22 59904 bytes
dxmasf.dll: 6.04.0009.1133 Spanish Final Retail 4/14/2008 07:48:22 499766 bytes
mciqtz32.dll: 6.05.2600.5512 Spanish Final Retail 4/14/2008 07:48:26 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 07:49:20 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 07:48:26 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 07:48:22 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
qcap.dll: 6.05.2600.5512 Spanish Final Retail 4/14/2008 07:48:34 192512 bytes
qdv.dll: 6.05.2600.5512 Spanish Final Retail 4/14/2008 07:48:34 279040 bytes
qdvd.dll: 6.05.2600.6169 Spanish Final Retail 11/3/2011 12:28:46 387072 bytes
qedit.dll: 6.05.2600.5512 Spanish Final Retail 4/14/2008 07:48:34 563200 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 22:51:34 733696 bytes
quartz.dll: 6.05.2600.6169 Spanish Final Retail 11/3/2011 12:28:46 1298432 bytes
strmdll.dll: 4.01.0000.3938 Spanish Final Retail 8/26/2009 05:01:17 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 07:49:20 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 07:49:20 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 07:48:24 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 07:48:26 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 07:48:26 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 07:48:26 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 07:48:26 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 07:49:20 154624 bytes
mswebdvd.dll: 6.05.2600.5857 Spanish Final Retail 8/5/2009 06:00:12 205312 bytes
ks.sys: 5.03.2600.5512 Spanish Final Retail 4/14/2008 00:46:38 141056 bytes
ksproxy.ax: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:49:20 129536 bytes
ksuser.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:26 4096 bytes
stream.sys: 5.03.2600.5512 Spanish Final Retail 4/14/2008 00:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 Spanish Final Retail 4/14/2008 00:09:52 5376 bytes
mspqm.sys: 5.01.2600.5512 Spanish Final Retail 4/14/2008 00:09:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 Spanish Final Retail 4/14/2008 00:09:54 7552 bytes
swenum.sys: 5.03.2600.5512 Spanish Final Retail 4/14/2008 00:09:54 4352 bytes
mstee.sys: 5.03.2600.5512 Spanish Final Retail 4/14/2008 00:09:52 5504 bytes
ipsink.ax: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:49:20 16384 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 07:49:20 118272 bytes
ndisip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:24 10880 bytes
streamip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:22 15232 bytes
msvidctl.dll: 6.05.2600.5512 Spanish Final Retail 4/14/2008 07:48:30 1434112 bytes
slip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:24 11136 bytes
nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:26 85248 bytes
ccdecode.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:24 17024 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 07:49:20 30208 bytes
msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 14:13:11 17920 bytes
kstvtune.ax: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:49:20 61952 bytes
ksxbar.ax: 5.03.2600.5512 English Final Retail 4/14/2008 07:49:20 43008 bytes
kswdmcap.ax: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:49:20 91648 bytes
vfwwdm32.dll: 5.01.2600.5512 Spanish Final Retail 4/14/2008 07:48:46 54784 bytes
wstcodec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:26 19200 bytes
wstdecod.dll: 5.03.2600.5512 Spanish Final Retail 4/14/2008 07:48:48 51200 bytes
DirectShow Filters
Códecs WDM de transmisión VBI:
Códec NABTS/FEC VBI,0x00200000,2,1,,5.03.2600.5512
Descodificador CC,0x00200000,2,1,,5.03.2600.5512
Códec WST,0x00200000,1,1,,5.03.2600.5512
DirectShow Filters:
QuickTime Audio Decoder Filter,0x00600800,1,1,,
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
QuickTime Video Decoder Filter,0x00600800,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.02.4450.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6169
Nero Audio Decoder 2,0x00600000,1,1,NeAudio2.ax,5.05.0021.0000
ffdshow DXVA Video Decoder,0xff800002,2,1,ffdshow.ax,1.02.4450.0000
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.02.4450.0000
RealPlayer Video Filter,0x00200000,1,1,rdsf3260.dll,15.00.0004.0053
ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.02.4450.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
MainConcept MPEG Demultiplexer,0x00800100,1,2,mc_demux_mp2_ds.ax,8.05.0000.14265
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6169
LAV Splitter,0x00400001,1,1,LAVSplitter.ax,0.50.0005.0000
MainConcept AMR Decoder,0x00800000,1,1,mc_dec_amr_ds.ax,8.05.0000.14265
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
MainConcept AAC Decoder,0x00800000,1,1,mc_dec_aac_ds.ax,8.05.0000.14265
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
Nero Splitter,0x00600000,1,3,NeSplitter.ax,5.05.0021.0000
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6169
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6169
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
MainConcept Color Space Converter,0x00600000,1,1,mc_trans_video_colorspace_ds.ax,8.05.0000.14265
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
MainConcept MP4 Demultiplexer,0x00800101,1,2,mc_demux_mp4_ds.ax,8.05.0000.14265
DivX AAC Decoder,0x00800000,1,1,daac.ax,8.08.0000.41966
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.6076
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MainConcept Layer II Audio Decoder,0x00600000,1,1,mc_dec_mpa_ds.ax,8.05.0000.14265
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6169
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
AsyncEx,0x00200000,0,1,AsyncEx.ax,
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
File Source (MP3),0x00400000,0,1,MP3Source.ax,
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6169
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6169
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
AC3 from AVI XForm,0x00680000,1,1,Decaudio.ax,2.02.0000.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.6169
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.11.0288.0000
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.11.0288.0000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
HP VTK MPEG-1 Encoder,0x00200000,3,3,hpqvtk01.dll,90.00.0146.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
Xvid MPEG-4 Video Decoder,0x00800002,1,1,xvid.ax,
File Source (Monkey Audio),0x00400000,0,1,MonkeySource.ax,
RadLight OptimFROG DirectShow Filter,0x00600000,0,1,RLOFRDec.ax,1.00.0000.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6169
madFlac Decoder,0x00600000,1,1,madFlac.ax,1.10.0000.0000
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6169
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.6076
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6169
DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,9.00.0001.0021
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6169
DivX Demux Filter,0x00600000,0,1,DirectShowDemuxFilter.dll,1.00.0003.0111
Haali Video Renderer,0x00200000,1,0,dxr.dll,
DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.03.0000.0048
HP VTK Rotate Filter,0x00200000,1,1,hpqvtk01.dll,90.00.0146.0000
MainConcept Audio Converter,0x00200000,1,1,mc_trans_audio_converter_ds.ax,8.05.0000.14265
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
MainConcept Audio Resampler,0x00200000,1,1,mc_trans_audio_samplerate_ds.ax,8.05.0000.14265
DivX Demux Filter (Unrestricted Edition),0x00600000,0,1,DirectShowDemuxFilter.dll,1.00.0003.0111
AC3 Prologic Decoder ,0x03680000,1,1,Ac3audio.ax,2.02.0000.0000
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Decoder,0x00600000,2,1,NeVideo.ax,5.05.0021.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.11.0288.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,vsfilter.dll,1.06.0002.4742
MainConcept AVC/H.264 Video Decoder,0x00800001,1,2,mc_dec_avc_ds.ax,8.05.0000.14265
DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,1.06.0002.4742
WAV Dest,0x00000000,0,0,,
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.11.0288.0000
MainConcept Frame Rate Converter,0x00400000,1,1,mc_trans_video_framerate_ds.ax,8.05.0000.14265
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6169
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
DC-Bass Source,0x00400000,0,1,DCBassSource.ax,1.03.0000.0000
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
RealPlayer Transcode Filter,0x00600000,0,0,rdsf3260.dll,15.00.0004.0053
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.02.4450.0000
LAV Splitter Source,0x00400001,0,1,LAVSplitter.ax,0.50.0005.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MainConcept MPEG-2 Video Decoder,0x00800001,2,2,mc_dec_mp2v_ds.ax,8.05.0000.14265
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
HP VTK Frame Grabber Filter,0x00200000,1,1,hpqvtk01.dll,90.00.0146.0000
MainConcept ImageScaler,0x00400000,1,1,mc_trans_video_imagescaler_ds.ax,8.05.0000.14265
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
VP7 Decompressor,0x00800000,1,1,vp7dec.ax,7.00.0010.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
madFlac Source,0x00600000,0,1,madFlac.ax,1.10.0000.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.6076
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,15.00.0004.0053
MainConcept Sink Filter,0x00200000,1,0,mc_render_fileindex_ds.ax,8.05.0000.14265
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6169
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6169
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6169
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
HP VTK Resize Filter,0x00200000,1,1,hpqvtk01.dll,90.00.0146.0000
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.02.4450.0000
MainConcept Stream Parser,0x00400000,1,2,mc_demux_mp2_ds.ax,8.05.0000.14265
madVR,0x00200000,1,0,madVR.ax,0.82.0005.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6169
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6169
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6169
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero MP4 Splitter,0x00600000,1,1,NeMP4Splitter.ax,5.05.0021.0000
LAV Audio Decoder,0x00800003,1,1,LAVAudio.ax,0.50.0005.0000
LAV Video Decoder,0x00800003,1,1,LAVVideo.ax,0.50.0005.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Haali Video Sink,0x00200000,1,0,splitter.ax,1.11.0288.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AC3File,0x00600000,0,1,ac3file.ax,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
Nero Video Decoder,0x00600000,2,1,NeVideo.ax,5.05.0021.0000
DScaler Mpeg2 Video Decoder,0x00800000,1,1,MpegVideo.dll,0.00.0006.0000
MainConcept MPEG-4 Video Decoder,0x00800000,1,1,mc_dec_mp4v_ds.ax,8.05.0000.14265
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6169
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Dispositivos de transmisión con derivador y separador WDM:
Convertidor de derivador/consumidor a consumidor,0x00200000,1,1,,5.03.2600.5512
Transformaciones de datos de transmisión WDM:
Eliminador de eco acústico de núcleo de Microsoft,0x00000000,0,0,,
Sintetizador de tabla de onda Microsoft Kernel GS,0x00200000,1,1,,5.03.2600.5512
Sintetizador DLS Kernel de Microsoft,0x00200000,1,1,,5.03.2600.5512
Descodificador de audio DRM del núcleo de Microsoft,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.02.4450.0000
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6169
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
DivX 6.9.2 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.5512
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Códec Intel IYUV,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6169
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6169
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6169
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6169
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.6169
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6169
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6169
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6169
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.6169
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.6169
Ley A CCITT,0x00200000,1,1,quartz.dll,6.05.2600.6169
Ley u de CCITT,0x00200000,1,1,quartz.dll,6.05.2600.6169
AC-3 ACM Codec,0x00200000,1,1,quartz.dll,6.05.2600.6169
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6169
Audio Capture Sources:
Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6169
Sint. SW de tabla de ondas GS,0x00200000,1,0,quartz.dll,6.05.2600.6169
Dispositivos de captura de transmisión WDM:
Realtek HD Audio Input,0x00200000,1,1,,5.03.2600.5512
VideoCAM GE111,0x00200000,0,1,,5.03.2600.5512
Dispositivos de procesamiento de transmisión WDM:
Realtek HD Audio output,0x00200000,1,1,,5.03.2600.5512
Filtros de procesamiento de BDA:
Receptor BDA IP,0x00200000,1,1,,5.03.2600.5512
Video Capture Sources:
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
Dispositivos mezcladores de transmisión WDM:
Mezclador de audio de onda Microsoft Kernel,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.6161
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.6161
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.6161
Transformaciones de comunicación de transmisión WDM:
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.6169
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.6169
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.6169
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.6169
Dispositivos del sistema de retransmisión WDM:
Realtek HD Audio Input,0x00200000,4,1,,5.03.2600.5512
Realtek HD Audio output,0x00200000,10,1,,5.03.2600.5512
Componentes de receptor de BDA:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
como no entiendo mucho quizá di datos de mas o de menos, bueno
en fin, espero ayuda
P en general funciona bien, lo unico que noté es que no reproduce el sonido de una llamada entrante de skype.
muchas gracias
    2 Soluciones propuestas
    en la lista de componentes que has puesto dice esto:
    Driver: n/a
    COMO VES ESE DISPOSITIVO NO TIENE DRIVER****
      El driver que te falta es según el código que me pasas:
      Intel 945G/GZ/GC/P/PL Processor to I/O Controller
      Toma descargalo aquí lo tenes, lo instalas, reinicia y valora si te sirvió
      http://ul.to/woc2slsk
      Saludos.
