Solo faltan 55.532 soluciones y llegaremos a los 500.000 articulos que no se convirtieron en CHATARRA o BASURA!!!
What Exactly Is Odin Download Latest Version v 3.13.1
Samsung Odin is the best ROM flashing tool available for Samsung Android smartphones and also tablet devices including Samsung galaxy note and Samsung Galaxy S8. Samsung Odin download is the path available for Samsung users in order to flash stock firmware, custom ROM, kernels as well as root packages.
Latest Odin Download v 3.13.1
The available latest version is Samsung Odin 3.13.1. Downloading available latest version is the best choice you ever can make in order to have an optimized function via a tool.
This latest release is more stable and compatible with new compression of the Samsung galaxy S8/S8+ / S9 / S9+ Oreo files
Samsung Odin Download Requirements
There are a few requirements that you should fulfill before download Odin.
The tool is compatible with Windows Operating system.
Latest Samsung USB drivers if necessary
ADB & FASTBOOT TOOLS for your Samsung mobile
Compatible USB cable to connect mobile and the PC
Odin Related Important Facts To Remember
Before engaging flashing kinds of stuff remember to take a complete backup of your mobile
Download Odin latest version. But it needs to be compatible with your mobile version.
Install the latest USB drivers
Download a Stock or custom ROM compatible with your device.
Latest Odin Download Troubleshoot Guide
Normally Odin compatible ROM flashable files available in .tar file extensions. You can download the most Odin compatible ROMs from Samsung Official or leaked ROMS, OTA updates.
Remember that it will not work with a .zip file extension.
Some Custom ROMs have .tar file extensions and such ROMs can flash into a Samsung mobile using Odin tool.
It is recommended you to follow more tutorials and as well as guides before engaging with flashing. It is somewhat risk associated task. So do not mess with the procedure.
How To Flash Samsung Stock ROM Using Odin
Users are able to track Odin download leaked version of the official tool. So the users can keep their trust regarding this application. You have to use a Windows PC or the laptop device in order to use this application. The tool is basically a windows based platform. If you have not installed Samsung USB drivers install them before you connect your device to the PC. Download a compatible ROM with your device is more important here as any simple mistake made by you could cause to brick your device.
Developer Credit
Samsung Odin Download development Credit goes to https://www.xda-developers.com/">XDA developers for their great contribution.
  • A porque poner esto en inglés en un foro en español?
  • hola compañero José estoy de acuerdo contigo recibe saludos cordiales y buenas tardes
  • hace 1 año
    dianarichiee
    use the google translation.
    Spanish: usa la traducción de google
  • perdón pero uso Edge de windowds 10 no me gusta el Google va demasiado lento aunque haciendo un esfuerzo trato de deducir que usted trata de reinstalar un firmware no tengo claro si de una Tablet o un móvil saludos oki.
Odin is a program for PC (Windows) that allows us to update and install manually official Samsung firmware on our device, that is, install the operating system with Android on our Samsung. It also allows other actions such as flashing ROM, recovery, kernel or partition, but the one that interests the majority of users is to be able to change the operating system of their Samsung. At the same time, it is the software that is used in specialized centers or technical services of Samsung to repair devices.sorry my english is not so good
