Solo faltan 55.688 soluciones y llegaremos a los 500.000 articulos que no se convirtieron en CHATARRA o BASURA!!!
Delay in starting
Hi. I have a notebook with windows 7. After logging in the first 15 minutes the use of cpu is 100%. Then he walks normal, but every time I have to wait that long.
It is one of the processes svchost.exe
Can you disable something to see what it can be?
regards
  • hace 2 años
    Avatar de repar2015
    and how can you tell if it is a software or hardware problem? that starting in error-proof mode is worth something?
  • hace 2 años
    Avatar de GordoRabino
    Starting in safe mode allows you to repair, uninstall or update drivers or possible windows crashes. In the case that the error occurred after some modification in windows or installed applications.
7 Soluciones propuestas
I THINK YOU WILL SERVE THIS> YOU HAVE TO TAKE IT ALL OF THE INFORMATION TRASH THAT YOU HAVE YOUR PC THAT IS INSTALLED IN FOLDERS THAT ARE NOT VISIBLE ... AHI CZECH EL LINK ... GREETINGS
  • hace 2 años
    Avatar de repar2015
    I guess it's not for that reason, that would make it a bit slow but in this case it's 15 minutes to log in ...
  • hace 2 años
    Avatar de JLMRNEO
    TRY IT! MY BEST SOLUTION WOULD BE SAVING ALL THE IMPORTANT AND FORMATING SO YOU DO NOT WALK BATTING AND IT IS LIKE BEING! BUT THERE ARE PEOPLE WHO LIKE TO SEEK.
  • hace 2 años
    Avatar de JLMRNEO
    CTRL + ALT + DELETE: TO VIEW THE PROCESSES> THAT YOU COME LIKE TO BE RELATED TO SOME VIRUSES AND SOMETIMES YOU DO NOT SEE IT. AND IF IT REFERS TO WINDOWS NT. I RECOMMEND BEST TO DO SOMETHING WHERE YOU KEEP YOUR MOST IMPORTANT AND FORMATE THINGS. SO YOU WILL BE MORE AGUS
  • hace 2 años
    Avatar de JLMRNEO
    IF YOU DO NOT WORK ANYTHING THAT> BETTER SAVE ALL THE IMPORTANT> AND FORMATEALA OF ROOT SO THIS WILL BE MUCH FASTER. IF YOU HAVE INSTALLATION DISCS WILL BE MUCH BETTER THAN RECOVERY FROM THE SAME PC
Friend you may be starting too many programs at the beginning and by which they are in the background, check the programs that start you
you can do this by clicking on start and typing "msconfig" and click where it says windows start, remove the programs you do not want to get started or if they have unknown names like "jahfñsja" just take them out that are viruses, reboot your pc and check what happened
tell us how was your day
    hello good afternoon how I deleted the virus direct access to my pc
      There is nothing in the beginning. I will expect some other solution. Formatting I never did
        you could use a free program called Adwcleaner is free and you clean the virus pc is very effective I recommend it.
        • hace 2 años
          Avatar de Matias Owens
          ADWCLEANER ENSERIO IS VERY EFFECTIVE you get it on the internet that if you type: "adwcleaner official page"
        Hello normalmete this problem is associated with viruses which today are stronger are hidden in many parts slowing your computer, you can try to eliminate them and it will take you a lot of time if you have a lot of experience, the best thing you can do is store your information in another unit different from your hard drive and format your computer as they have previously proposed these is faster and we can rule out damages in the equipment if any. luck and comment
          Hi, I recommend that you install programs such as tune up, advance system clear, etc. which will guide you and repair conflicts, errors, programs running in the background and everything that causes slowness and instability of the system. Try at least to get out of step and check that it is nothing other than a little order of your system.
          I hope I have been helpful.
          Regards!!
