Tienda | Foros | Blogs | EN |
like sack in my house from 110v to 220v
Friends in my house I have 110v current I need to have 220v as I would to get who gives me clues
4 Soluciones propuestas
Hello
Are you from Mexico or Venezuela ?, wait for the contribution of the colleagues from there.
They will explain how to request another phase so that you have 110 between phase and neutral; and 220 v between phases.
This new phase you must ask the service provider.
Wait for the details.
regards
  • hace 2 años
    Avatar de Gato_Aca
    If you are from Mexico, I gladly support you, but based on the devices you have asked about, I do not think it's from here.
  • hace 2 años
    Avatar de nastor
    Hello Cat.
    Talk about having 110 volts and you want 220 volts, not appliances
  • hace 2 años
    Avatar de Gato_Aca
    Eh yes, but you comment that you can request another phase, in the assumption that it is Mx or Vz by having 110V. When checking your profile, I see that you have many questions about devices with brands that here in Mx I have not heard (I did not know hyundai for tvs ... here only sells cars). Of course it might be, but my guess is no.
  • hace 2 años
    Avatar de Gato_Aca
    But in case it is, that's why I said that I gladly helped with the information to request the other phase to CFE (the electric company of Mexico)
  • hace 2 años
    Avatar de nastor
    Ok, do not investigate so much, hopefully it will be the interested party to clarify. For what you say is not from Mexico. Let's hope.
  • hace 2 años
    agustinp
    nastor, if you have 110v single phase it is obviously going to have 220v between phases
  • hace 2 años
    Avatar de nastor
    Exactly Agustin
Hi. You only have 110V? Do you have one or two phases? As for you to take into account between each phase and the neutral you have 110V, between the two phases you get the 220V. regards
  • hace 2 años
    Avatar de oscar gomez2014
    Good colleagues excuse the delay in commenting had no signal and good
  • hace 2 años
    I am from venezuela and I have 2 phases of 110v as I would
  • hace 2 años
    Avatar de servimat1
    Moderador
    Among them you have the 220V you need. Do not use the neutral. regards
Good evening, Oscar Gomez2014.
Since you have two different phases plus the neutral, all you have to do is take the signal from both phases to get the single-phase 220 VAC which in fact in Vzla is in the order of 240 VAC. Nothing leads the neutral that circuit.
It is of note that you should specify so that you require the 220 VAC. There are appliances that work on the one hand with an average 120 VAC signal that includes one phase and the neutral, while on the other side in the same appliance the two different phases are required. For example: dryers with washing machine in two different modules. Dryers only as the case of the Mabe brand for example whose resistors work with 240 VAC for maximum temperature but at 120 VAC for the main motor, fan, etc.
Do not confuse the neutral with the physical earth. They are two very different things and in your case the neutral is the one that goes in the circuits to obtain the 120 VAC.
Thanks and regards.
PS: It would be very interesting to know so that you are going to use the 240 VAC you require. Thank you.
Approach I:
-8 hours ago From: oscar gomez2014. I'm from venezuela and I have 2 phases of 110v as I would do.
Observations:
Oscar: There are no 110 V phases. The voltage between phase and neutral is in the order of 110 VAC to 127 VAC for phase-neutral single-phase circuits. While between two different phases, the voltage will be in the order of 220 VAC to 254 VAC for circuits that require: Air Conditioners, Welding Equipment, Dryers only to work with that voltage for example.
Hello Oscar.
Simple Solution: Elevator transformer. from 220v to 110v it is clear that the power is calculated according to what you are going to connect.
Regards!
  • hace 2 años
    But between the two phases does not make short
  • hace 2 años
    Avatar de Gato_Aca
    But not united to each other. Each one at a different pole.
Ver pregunta en English : like sack in my house from 110v to 220v
