epson l210 blink paper led and drop reset
good day epson l210 tried to run the reset but when i give the first option i get the error comunication rror code 20000101 and did not finish doing the rest agradesre help
  • hace 2 años
    Avatar de Raffles
    You mean reset pad ?!
2 Soluciones propuestas
Now look at that error that throws you is x the reset ok try with the one of here keep in mind that you must indicate the error of pads and the lights of the printer the paper and ink must interleave https: // depositfiles. org / files / gxsjmbiwp? redirect
agradesco the tip the company epson l211ya quedo if it was l reset you agradesco help
  • hace 2 años
    Avatar de josezasa29
    value man then ???
  • hace 2 años
    Avatar de abel blas ayuzo
    ALREADY HOW TO VALUE YOUR HELP BUT I CHANGE THE VALUATION FORMAT AS I SEE AND DO NOT FIND HOW TO DO IT
Ver pregunta en English : epson l210 blink paper led and drop reset
