Solo faltan 51.839 soluciones y llegaremos a los 500.000 articulos que no se convirtieron en CHATARRA o BASURA!!!
modo service tv telefunken modelo tkp 2167
hola a todos, con el animo de intercambiar experiencias en el futuro 30 ( años la mia) es que me suscripto a yo reparo, como bautismo les agradeceria me informaran como entrar al modo service del tv 21 telefunken modelo tkp 2167 ( plano) desed ya muchas gracias y quedo a la reciproca.
    Factory settings
    D-mode:
    Enter D-Mode by pressing D-Mode ON/OFF key, and then you can enter the D-mode.
    S-mode:
    Enter S-Mode by pressing VOLUME DOWN key on the unit until the
    volume decrease to minimum level, then press the DISPLAY key on the remote
    handset (don’t release the volume key) and you can enter S- mode.
    After enter D-mode or S-mode, press OK, then press program up/down to
    select menu from menu 1 to menu 22, press OK to enter the menu, press program
    up/down to select item, press volume up/down to adjust the setting. Press D-mode
    again to quit factory mode.
    You can also enter menu 1 to menu 19 directly by pressing digital button 1~9,
    0, notebook, CAP, Display, Sleep, Calendar, System/INS, Favorite, Return, Picture.
    Suerte y bienvenido.
